Hot Rods Trans mount opinions
Discussion in 'The Hokey Ass Message Board' started by Bumpstick, Mar 2, 2024.
  1. Bumpstick
    Bumpstick
    I'm gonna use a turbo 350 on a project and would be interested on the tail mount opinions. Solid or rubber? Not drag racing or anything, just a cruiser. Thanks, Bumpstick
  2. squirrel
  3. i7083
    i7083
    You definitely want rubber
    Truckdoctor Andy and jimmy six like this.
  4. verno30
    verno30
    Unless there is some special reason to the contrary, you definitely want rubber.
  5. 38Chevy454
    38Chevy454
    Cruiser definitely rubber mount.
    Truckdoctor Andy likes this.
  6. RodStRace
    RodStRace
    When you are running solid tires, solid motor mounts and solid axles with no springs, use solid trans mount. :p
    Get a quality mount, unless it's really easy to change out. Lots of cheap stuff out there that isn't worth your pennies.
    Truckdoctor Andy and Bumpstick like this.
  7. What motor mounts are you running? Because that will dictate which transmission mount
  8. squirrel
    heh...so if I'm running one solid motor mount, and one rubber motor mount, what transmission mount do I use?
    answer: rubber, because what the transmission mount attaches to isn't very strong
    fastcar1953 and 41 GMC K-18 like this.
  9. alchemy
    alchemy
    Even if I used solid motor mounts, I’d use a rubber trans mount.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
  11. lostone
    lostone
    from kansas
    Anybody know what the height of that mount itself is?
    I need to build a mount for my 31' Tudor with a 727 and I can't use the stock mount, gotta build a custom one...
  12. Bumpstick
    Bumpstick
    Just a rubber biscuits on a small block chevy
  13. RodStRace
    RodStRace
    Your best bet is to find a parts store that still has paper catalogs with dimensions. However, the second best is to look through Rock Auto at different years and body styles. I checked a few and although they didn't have sizes, they did have pictures.
  14. bobss396
    bobss396
    My mounts are a set from Energy Suspension, very good quality, zero complaints.
    With the stock cars, some guys used solid mounts. One had a hard crash, bent the front clip and the solid mount took out the side of the engine block.
  15. Jmountainjr
    Jmountainjr
    For a street car I can't think of a reason you would use anything but a rubber trans mount. It doesn't take much to crack a transmission tail shaft housing. As to the height of the mount, they are easily shimmed if needed.
  16. 38Chevy454
    38Chevy454
    Even if you run solid engine mounts, if you run solid trans mount you risk cracking your tailshaft. You need to have some give in the mount setup. In addition, in street car a solid mount will transmit more vibration and noise to the car. Just use a rubber trans mount.
    Paulz likes this.
