Trans or Tork Converter
Discussion in 'The Hokey Ass Message Board' started by swaluda, Jul 27, 2013.
  1. swaluda
    swaluda
    from pa.
    Waiting for light to turn green and gave it gas to go. Heard a turbine kind of whirring sound and had no forward or reverse either. Anyone ever had that happen, if so, what would the problem be? Stan
  2. SMOG_GUY
    SMOG_GUY
    from Dinuba
    First you check trans fluid level per factory instructions. Look for leaks.
  3. swaluda
    swaluda
    from pa.
    no leaks and fluid is red
  4. Okatoma cruiser
    Okatoma cruiser
    from Ms
    I would pull the trans pan and check it for metal- and what kinda car?
  5. themoose
    themoose
    What transmission is it?
    Could be a pump problem. Start by checking pressure.
  6. swaluda
    swaluda
    from pa.
  7. You'd have been better off stating an answer to the question - "what transmission is it ?"
    Because a. 1987 olds 88 is not a type of trans and its off topic.
  8. d2_willys
    d2_willys
    from Kansas
    broke input shaft
