transmission cooling
Discussion in 'The Hokey Ass Message Board' started by Ole Pork, Jan 19, 2007.
  1. Ole Pork
    Ole Pork
    Hey, we all know what that thing they call a ****** cooler on a '51 Powerglide looks like. I'm going the 350/350 route, and have a really, really nice original radiator that I would like to get cleaned, pressure checked and use. I am wondering if the aftermarket ****** coolers that go in front of the radiator would be adequate. Wadda think? Ole Porky
  2. Probably more than adequate unless you have a high stall torque convertor.
  3. I had one made by B&M and ran it for years with no problems. Cost about $45 from Summitt. I'd get one of the bigger ones.
    Bill
  4. andysdeuce
    andysdeuce
    I've got one from b&m. I mounted it on the frame rail and fabbed a lttle air scoop for it. Then just run the lines to your ******. I'm running a turbo 400 with a shift kit and a 2500 stall. It' been in there for about six years now with no problems.
  5. Enginetuner
    Enginetuner
    I run a little cooler on mounted on the rear axle housing on my 31 A, works great for over a year now in the Texas heat.
  6. Bugman
    Bugman
    The B&M Megacooler is one of the few quality products that B&M makes. I wouldnt hesitate to use it.
  7. denis4x4
    denis4x4
    from Colorado
    While you're at it, install a transmission fluid filter and temp guage
  8. If your motor/****** package is mostly stock why not have a kooler loupe installed it the lower tank while being cleaned.
    Stock style work fine in most cars.
    The Wizzard
