Transmission--flywheel question
Discussion in 'The Hokey Ass Message Board' started by keithl1967, Feb 24, 2009.
  1. keithl1967
    keithl1967
    I'm noticing, as I shop for a flywheel for my transmission conversion, a couple of things that I don't know/surprise me...
    I have a 383 stroker, so I need an externally balanced flywheel:
    I've seen a few flywheels advertised as 32#--is that a normal weight?
    what is "pitch" I've seen them advertised with 12-14 pitch?
    Thanks!
  2. 1934coupe
    1934coupe
    I gather you have a SBC 383 stroker. You need a flywheel that fits a 400 CU. IN. Chevy which is EXTERNALLY BALANCED. The total weight has nothing to do with it being externally balanced. A 32# wheel will work if it is for a 400 cu. SBC.
    As for the pitch I never heard of that term referring to flywheels. Hope this helps.
    Pat
  3. keithl1967
    keithl1967
    Thanks for the response...I do indeed have a 383...questioning the weight, becaus the "flexplate" currentl yon it for the auto is quite lightweight...just an observation, as I attempt to learn about this stuff
  4. Ditto. I'll add that Speedway sells a weight to convert a 350 flywheel for use on the 400 or 383. It won't fit behind the smaller 13" (153 tooth), but it will on the 14"(168 tooth). Anyway, if you or a friend has a 350 'wheel, it's a cheap way out
  5. Retro Jim
    Retro Jim
    Have you tried the salvage yards up your way yet ? Also look on C. List too .
  6. Finding THAT particular flywheel in a salvage yard would be near impossible. On C-list, you may get one for a 454 from someone that doesn't know any better. Beware, or you'll do some damage with the wrong flywheel. Better buy that item new, rather than chance a problem with vibration. They are externally balanced, unlike most other SBC's
  7. keithl1967
    keithl1967
    so...a 454 flywheel will work also?
  8. nooo!
  9. r759ca
    r759ca
    from nor cal
    it really depends on whether he is using a turned down 400 crank or an aftermarket crank, alot of aftermarket cranks use 350 flywheels. are you using a 400 balancer as well
  10. keithl1967
    keithl1967
    It is a turned 400 crank...it is externally balanced...
  11. keithl1967
    keithl1967
    How do I knoe if one is "usable" or not...I've heard a couple of folks mention "turning" the flywheel...
  12. Shifty Shifterton
    Shifty Shifterton
    You know it's useable when you go buy an SFI rated flywheel. A brand new one. You have a performance engine and it's time to step up with a necessary safety feature. Good luck
  13. keithl1967
    keithl1967
    Point taken...I've sen acouple of brand new ones on ebay for between $115 and $135...
    probably wirht a few extra $$$ to get ine of these new
    I guess I just enjoy the parts hunt!
  14. THAT particular part prolly won't be the one to hunt for, as there's too much at stake. Very few 400's came with a stick, and the 454 flywheel looks close, but is not interchangeable. Buy the right one, and have fun hunting other parts.
  15. Shifty Shifterton
    Shifty Shifterton
    Is that an actual billet SFI flywheel, or just a cheapie cast iron flywheel? Great price if it's SFI.
    good luck
  16. keithl1967
    keithl1967
    I suppose they are cast iron...although I have seena few that list themselves as Steel...SFI
