Technical Transmission for Continental Engine
Discussion in 'The Hokey Ass Message Board' started by '34 Ratrod, Feb 3, 2023.
  1. I'm in the process of acquiring a welder with a Continental engine. Is there a transmission that will bolt up to it?
    The welder
    What I have in mind to build
    I'm not worried about speed at all, I'm thinking of a parade vehicle to advertise my business.
    Thanks for your input.
    Larry
  2. Boneyard51
    Boneyard51
    Might try a T0-30 Ferguson tractor! They had Continental engines in them, but they were not flatheads! Could be the same…..maybe!
    Bones
    Budget36 likes this.
  3. Awesome. Thank you Bones.
    Larry
    Boneyard51 likes this.
  4. gimpyshotrods
    gimpyshotrods
    The answer is probably.
    To the best of my memory these have an SAE bellhousing pattern. You will need to measure a few things to figure out which one.
    Here's a good description of the dimensions: https://www.sbmar.com/articles/understanding-bellhousing-and-flywheel-measurements/
    For a parade car, an automatic would be best.
    SAE adapters to conventional automatics can be had here:
    https://phxgrp.com/engine-auxiliary/transmission-adapters/
    https://www.hayescouplings.com/products/sae-housing-adapters/
    The first site that I provided has enough dimensions that you could have a local shop with a big enough mill make you what you need.
  5. Thank you Gimpy.
    Larry
    goboy33 and gimpyshotrods like this.
  6. gatz
    gatz
  7. Boneyard51
    Boneyard51
    Don’t thank me yet! Like Gimpy said , but the Continental doesn’t have that bellhousing. It has its own pattern , but there is an adapter that takes that engine to an SAE pattern! I think! Lol
    Bones
  8. gimpyshotrods
    gimpyshotrods
    Or just plot the holes of that pattern, and make a Continental to GM, Ford, or Chrysler adapter, with no intermediate adapter.
    *And everything I can find on the interwebs says that it has an SAE bellhousing pattern.
  9. Boneyard51
    Boneyard51
    I was under the impression that the SAE bell housing was a complete circle roughly 28 inches in diameter with equally space bolts. Like what the Allison’s have. The Lincoln welder Continental has a very small bolt pattern on the back of the engine, IIRC! But I am sure there exist an adapter to take it to SAE.
    Bones
    Elcohaulic likes this.
  10. gimpyshotrods
    gimpyshotrods
    There are no fewer than NINE SAE bellhousing diameters.
    The smallest is a 11.25-inch circle.
    The largest is a 33.50-inch circle.
    Hnstray, winduptoy, 302GMC and 2 others like this.
  11. Boneyard51
    Boneyard51
    I knew there were several, did not know there were nine sizes. I am most familiar with the ones that are common behind the medium size gas and diesel engines that use various transmissions! I was just guessing the 28 inch , from memory, I haven’t been into one in years!
    But if the OP can get the little Flathead to an SAE bellhousing, he should have some transmission available, But that’s only 1/2 of it, not sure what he will do for a clutch! Maybe the Ferguson!
    Bones
  12. studebakerjoe
    studebakerjoe
    Kaiser-Frazer used a 226 based on Continental. If the pattern is the same you could use one of their bellhousings. Don't forget to check old Willys pickups and wagons. They often had the 226.
    winduptoy, Squablow, squirrel and 2 others like this.
  13. Those engines were used in a lot of different pieces of wheeled equipment such as fork trucks, airport tugs, etc. as well as farm equipment. Not normal pick-and-pull stuff, but there's got to be a lot of parts out there...
  14. vtwhead
    vtwhead
  15. Check older Clark and hyster / Yale forklift from the 80’s on back they used conti engines
    some where m****l and same where 2 speed autos or 1 speed autos .
    For a parade car would probably work well .
  16. pirate
    pirate
    from Alabama
    While you are searching, Continental engines were also used in boats. I think some of the old Chris Crafts as well as others used the Continental engine. It would be just a forward/reverse trans but it might lead you to a bell housing that would fit other transmissions.
    Boneyard51, Elcohaulic and '34 Ratrod like this.
  17. Boneyard51 likes this.
  18. Fitty Toomuch
    Fitty Toomuch
    from WVa
    Looks like an old Lincoln SA-200, which would have more value to be sold as is and just use the money to buy an old car flat head with it`s transmission.
    The welder has the magneto and governor to delete/deal with.
    rod1, Boneyard51 and lostmind like this.
  19. hoop
    hoop
    Older Checker Cabs had Continental engines.The 62 and 63`s that I worked on had Ford style Borg Warner auomatic transmissions .
    sunbeam likes this.
  20. rusty valley
    rusty valley
    My 29 Durant has a continental motor in it. Running ch***is...too bad you are a long ways from here
  21. gimpyshotrods
    gimpyshotrods
    Keep in mind, if you need an adapter, and you either are not a machinist with a shop, or not have access to an inexpensive one, you will have to purchase a pre-made one.
    Those are often not inexpensive.
    You would need to compare that cost, and any other ***ociated costs with using this "free" engine, against the cost of just using a matched combo.
  22. Fabber McGee
    Fabber McGee
    Blues4U and '34 Ratrod like this.
  23. AccurateMike
    AccurateMike
    Larry, M***ey Harris Pony used a 1L (61") Continental 4cyl flathead. Trans itself is a pretty ungainly casting though. Mike
  24. Fabber McGee
    Fabber McGee
    I just noticed that the exhaust is uncovered, does the engine turn?
  25. PhilA
    PhilA
    Or put that in up front and an electric motor up back.
    Would cruise the parade just fine!
    '34 Ratrod and Squablow like this.
  26. squirrel
  27. Budget36
    Budget36
    I have an old Clark lift, I’ll snap a pic of what the BH area looks like. Been so long I don’t remember if it’s a 4 or 6 Continental.
  28. Squablow
    Squablow
    This is actually an interesting idea. The welder is basically a gas powered electricity generator, correct? Could it be used in it's entirety to power an electric motor to move the speedster around? Either directly, or through a bank of batteries.
    If you're just wanting to build a conversation piece/advertising car to use in parades, a gas/electric hybrid made of 75+ year old components would be really interesting and get a lot of attention.
  29. PhilA
    PhilA
    Don't see why not, though to charge batteries would be the most sane method, with a motor controller (fork lift style) running the electrical portion.
    Squablow likes this.
  30. BJR
    BJR
    That's how diesel locomotives work, engine runs generator, generator powers electric motors to move the train.
    PhilA likes this.
