Transmission help. 700r4
Discussion in 'The Hokey Ass Message Board' started by DIRTYT, Dec 23, 2006.
  1. DIRTYT
    DIRTYT
    from Warren,MI
    Got some ****** questions for you guys. Can a 700 out of no where loose all its gears? no reverse no low no 2nd no d or od? fluid is clean and topped off detent cable is adjusted proberly and in working order but the ****** will not power the car? im at a loss here and need some info. ive never heard or seen a ****** drop off the face of the earth with in 5 miles as this one did.
    any help would be great
  2. Fat Hack
    Fat Hack
    from Detroit
    He IS putting it in "DRIVE", isn't he???:confused:
    Your cat blows!!!:p
  3. JimA
    JimA
    Not a help with that exact trans, but I had a CATASTROPHIC failure a couple years ago with a 2 year old Chrysler automatic trans- it destroyed EVERY gear with one light POP! Problem was a plugged cooler line. Inside it looked like a grenade blew- happened 16 miles from my house- NO warning.
  4. Gregg Pellicer
    Gregg Pellicer
    Could be the pump has failed.Check your fluid level with engine off .Then check it with engine runing.If level doesnt go down when engine is running the pump aint working.GREGG
  5. 29ZZ4FORD
    29ZZ4FORD
    from NWFLA
    I second the pump. Check fluid as stated above.
  6. 50shoe
    50shoe
    pump, they can go in an instant. if this thing was from a yard who knows.
  7. 40Standard
    40Standard
    from Indy
    if the t c wasn't locked in, the pump will wipe out as soon as you start the engine
  8. Fat Hack
    Fat Hack
    from Detroit
    Another thought...are ya sure the shipper trailered it there? If he flat-towed it for any reason, that could toast the ****** pretty quick!!
  9. hotrodladycrusr
    hotrodladycrusr
  10. wvenfield
    wvenfield
    If it had been running fine, I'll bet it's the pump also.
    Here is another thought though. Any weird racket before hand? You didn't shear your flexplate did you?
    I have very little experience with the 700r4 but I do with the 4l60e which is basically the electronic version. Alot of people have cracked their flexplates and thought they lost the ******. This is at least an easy one to rule out or not.
  11. DIRTYT
    DIRTYT
    from Warren,MI
    Thank you the all mighty who knows all.:rolleyes: but i did have it done with a guage after i got it close enough my self. it was done by the trans shop around the corner from me. So go bake some ****ing cookies
  12. Duration
    Duration
    from Wayne, MI
    sounds like the front pump is fried or it has dirt blocking a p***age in the valve body. both are common problems. I agree if it was flat towed that would hurt it if it went far that way. try holding the brake and applying throttle in gear. That will build lots of pressure and can blow a spec of dirt out. its worked for me before.
  13. Are the flex-plate-to-torque-converter bolts ok?
  14. Thre car was trailered all the way.
    NO LUck
  15. [quote='29MurrayTub]Are the flex-plate-to-torque-converter bolts ok?[/quote]
    yes
  16. AnimalAin
    AnimalAin
    Not on a 700R4 (my transmission is an AOD), but I lost the whole thing at once, also. Turns out that the splines on the output of the converter stripped, which resulted in no power transfer. The transmission itself was ok, but it got no torque from the motor.......
    Kind of an unusual failure, but maybe something similar could be the problem.
  17. 1930 A
    1930 A
    I work in a transmission shop and have seen a few 700R4's where the insides of the torque converter break loose. Instant no gears.
  18. hotrodladycrusr
    hotrodladycrusr
    Well excuse me for throwing a hint out there that I thought might help. I won't bother next time....***hole:rolleyes:
    and no where in your other post did you mention that you took it to a professional shop.
  19. DIRTYT
    DIRTYT
    from Warren,MI
    Please dont I dont value your opinion. And im preety sure you dont know **** about transmissions. much less the rest of a car
  20. hotrodladycrusr
    hotrodladycrusr
    Sounds like your a little touchy because perhaps I referenced your other trans post???:eek:
  21. fuel pump
    fuel pump
    from Caro,MI
    Its Christmas.... can't we all just get along :confused: or maybe not:eek:
  22. For real......I'd like to find a solution......so I can DRIVE it!!!!!
  23. hotrodladycrusr
    hotrodladycrusr
    I feel for ya bud. PM Crosley, he's a transmission guru in AZ, perhaps he can steer you in the right direction. He might miss this post with it being the busy Christmas holiday season so you should contact him instead of waiting for him to see this post. Good luck
    http://www.jalopyjournal.com/forum/member.php?u=62
  24. 40Standard
    40Standard
    from Indy
    haha, that's some funny ****
  25. Cruiser
    Cruiser
    DirtyT,
    :mad: My 700R4 took a dump last year. Heard a clunk and couldn't go over 15 miles an hour after that and barely make it home. It had no reverse and it would barley move forward with a lot of gas..
    "Drive a cool short" - make mine a custom
    Cruiser 49:cool:
  26. Crosley
    Crosley
    from Aridzona
    I am a bit late to the game here.
    If trans has good pressure and will NOT move in any gear 1-2-3-4-R
    I would suspect the converter spline hub inside the converter . The hub can break from the turbine and all power transfer stops
