Technical Transmission help?
Discussion in 'Traditional Hot Rods' started by Brandon141, May 24, 2023.
  1. Brandon141
    Brandon141
    This AOD ford trans E90P-7006-AA is bolted to my 302 now. I just lost 3 &4th gear. Can anyone tell me if this ford AOD will bolt rite up RF-FOTP-7006-CB. I think it will since one is an 1989 and the other is a 1990. I just want to be 100% before buying it. I’m not running any cruise or nothing like that. Thank you.
  2. Beanscoot
    Beanscoot
    I can't answer that, except to confirm that it might not, as some later AODs had the Ford "Modular" V8 engine bellhousing.
    Also be aware that at some point the 3/8" starter bolt threads were changed to 10mm.
  3. jimmy six
    jimmy six
    There are parts on Ford engines and transmissions that changed in the middle of a week during manufacture. Good luck.
    Illustrious Hector and JimSibley like this.
