Transmission issues
Discussion in 'The Hokey Ass Message Board' started by DAPER DAVE, Aug 16, 2011.
  1. DAPER DAVE
    DAPER DAVE
    from N/A
    I have a 1962 Ford Falcon. The two speed automatic is having trouble going into 2nd gear. I have to drive the car for 10 min before it shifts into second gear. I checked all hose line connections for va***e leaks and did not find any issues. When the car warms up the transmission shifts fine but when it cools down its back to staying in 1st gear. Anyone know what is causing this problem?
  2. pcterm2
    pcterm2
    just for grins drop the pan and check the filter
  3. Shift modulator is junk. Some of them are adjustable sometimes too.
  4. Cerberus
    Cerberus
    I had a '66 Olds Jetstar 88 that did the same thing. It had to warm up before shifting into forward gears. Trans shop said it was old tired seals.
  5. DAPER DAVE
    DAPER DAVE
    from N/A
    I will take a look at the transfilter for a start then adjust the shift modulator. If that dont work I'm getting another transmission.
