transmission mount
Discussion in 'The Hokey Ass Message Board' started by Paul, May 8, 2004.
  1. Paul
    Paul
    Editor
    here is post number eighteen in my modified build series
    today I put together a transmission mount to carry the Stude T86
    this is, as all of my posts in this series, very basic hot rod building stuff.
    here is how I did it.
    the Lark that I took this transmission from used the two bolt holes in the bottom of the bell housing to mount the trans.
    I want to use the two bolt holes at the bottom of the transmission itself to move the bearing point further back towards the tailshaft.
    the forward holes take 1/2" bolts and the rear holes take 3/8".
    here you can see both sets of holes.
  2. Paul
    Paul
    Editor
    the spacing on a Chevy transmission mount is almost exactly the same as the Stude but the Chevy uses 7/16" bolts.
    so I drilled and tapped the Stude transmission with both a regular and bottom tap to take the bigger bolts
  3. Paul
    Paul
    Editor
    and bolted the mount in place
  4. Paul
    Paul
    Editor
    then I layed out the bracket that will bolt to the mount and drilled it to take the lower bolts
  5. Paul
    Paul
    Editor
    I bolted it in place to check fit and layed a piece of 1-1/2"x2-1/2" tube on it that I will use to build the crossmember out of.
  6. Paul
    Paul
    Editor
    it looked ok so I cleaned the bracket up a little and bent the tab for the angle of the motor/transmission
  7. Paul
    Paul
    Editor
    and cut the tube to attach it to the frame
  8. Paul
    Paul
    Editor
    tacked it all together and checked it's fit, and took a totaly out of focus picture [​IMG]
  9. Paul
    Paul
    Editor
    it actually looked pretty good so I welded it all up
  10. Paul
    Paul
    Editor
    removed the wood shims the trans has been sitting on, bolted the new mount in place and tacked it good
  11. Paul
    Paul
    Editor
    and there ya have it!
    still a ways to go, but it's coming along. [​IMG]
    to be continued!
    Paul
  12. Fat Hack
    Fat Hack
    from Detroit
    Damn you, Paul! [​IMG]
    I struggled through routing some lousy steel brake lines today...and you made a whole TRANS MOUNT?
    I feel like a retarded kid trying to play the Star Spangled Banner on a rubber band next to Eddie Van Halen ripping out one of his blazing solos!
    You ROCK!!!! [​IMG] [​IMG] [​IMG] [​IMG]
  13. burger
    burger
    Paul,
    Keep it up, man!
    Ed
    PS - What do you use to cut metal? I suspect it isn't a jigsaw.
  14. bustingear
    bustingear
    60" Style you are a Pro Kat! You can work in my garage without getting paid anytime!
  15. Paul
    Paul
    Editor
    [ QUOTE ]
    [/ QUOTE ]
    depends on the job, today it was the plasma cutter and chop saw.. [​IMG]
    Paul
