Technical Transmission pan magnet
Discussion in 'The Hokey Ass Message Board' started by 36roadster, Apr 7, 2023.
  1. Budget36
    Budget36
    The “refrigerator “ type magnet in the 700r4 I have, didn’t have that much on it. Wow.
  2. Joe H
    Joe H
    Allison puts magnets on the filters, when you change the filter, you move the magnet to the next one after cleaning. Most all used a magnet inside the pan with no glue.
  3. Harv
    Harv
    from Sydney
    I’ve got a TCI aluminium pan on the TH350 in my avatar. It came with a steel drain plug with an inbuilt magnet. There were a few slivers on it last oil change, a few flecks of aluminium glitter in the pan, and a small amount of black inorganic stuff on the bottom (the bulk fluid was beautifully clean). Car gets wailed on repeatedly at the track, and daily driven.
    cheers,
    Harv
    Desoto291Hemi and '28phonebooth like this.
  4. bchctybob
    bchctybob
    I’ve done my own transmission fluid and filter changes for years and I’ve never had that much metallic debris in the pan. Usually just very fine black and silver powder in the residual fluid. Those similar-sized pieces of metal would tell me something is wrong and that the trans needs to come apart. So the magnet may be helping prevent additional damage, but it looks like that one is eating itself up.
    X-cpe likes this.
  5. 1971BB427
    1971BB427
    from Oregon
    Transmission housings don't wear really, so what the housing material is has little affect on metallic particles inside the trans. Clutches are non metallic, but clutch plates are steel. The clutches in an automatic transmission have the greatest wear of any parts internal to a transmission, and the steel plates between clutches That stack of clutches, and steel plates can create a lot of very fine particles that can eventually plug up orifices, and cause trans failure. A magnet is cheap insurance to keep all thos particles trapped in the pan.
    X-cpe and Desoto291Hemi like this.
  6. You can bet that the factory puts those there for a reason .
    Otherwise,,they would save the cost of the magnet .
    There are plenty of steel parts in an automatic,,,,,usually just make a metallic powder .
    Big slivers need to be caught so they don’t also destroy the pump and valve body .
    Tommy
    X-cpe and mad mikey like this.
  7. justpassinthru
    justpassinthru
    Back in the day, we used to tell new guys starting out in the transmission field, the magnets were there to polarize the valvebody.
    Many believed it.
    Bill
    X-cpe likes this.
  8. CSPIDY
    CSPIDY
    First there is fuzz
    then there are slivers
    then you get chunks
    eventually you can read part and serial numbers
    bchctybob likes this.
  9. gene-koning
    gene-koning
    I had one that when I dropped the trans pan, everything had a thick coating of aluminum dust and small chunks. The magnet was covered with chunks of steel and metal slivers. What amazed me most was I actually drove it into the garage before I dropped the pan. The rebuild was done on a complete used transmission and the original was the core at the JY.
