Ive probably a common question - I tried to search for it, but without any useful result. Which Automatic transmission can I - how - connect to a 37 Studebaker engine (R6) or where can I get an adapter for such a project. I want to build up a traditional rod from a 37 Stude Coupe, but due to an accident I need an auto****** in my cars. If this wont work which engine/transmission combo should I use? (without the 350/350 possibility) Thanks in advance!
Welcome to the Hamb Poncho!!! Normally this area of the forum is related to testing post and questions regarding the forum operation. If you post this on the regular forum you will get more responses. Good luck! PJ
I only know of Stude V-8 transmission adapters but the later 6's used automatic transmissions (Detroit Gear 150's and Flight-o-matics) that can be rebuilt or maybe use a Stude V-8. deepnhock@cox.net is the Stude newsgroups resident '37 Stude hotrodder, he has a coupe express and is up to speed on what fits..
