transmission question
Discussion in 'The Hokey Ass Message Board' started by js, May 10, 2007.
  1. js
    js
    from texas
    I've recently purchased a rebuilt 350 transmission. It has been awhile since I've installed one but I was thinking that the speedometer gear was on the drivers side but this one is located on the passenger side. Is this correct? Also will a gear assembly from a powerglide work on a 350?
    Thanks, John
  2. squirrel
    Wow, I"ve never seen that....
    is the tailhousing on upside down?
  3. junior 1957
    junior 1957
    what he said, if the speedometer gear hole is above the center line of the output shaft the tail housing is on upside down, don't know bout the powerglide gear
  4. js
    js
    from texas
    Does it have to removed and turned over. Don't mean to be stupid but didn't really want to have to tare everything down again.
    Thanks
  5. squirrel
    should be easy to fix if that's the problem, there is an o ring that seals the tailhousing to the case, just remove the 4 bolts and pull it off about 1/2", turn it over, push it on, install the bolts.
  6. Slonaker
    Slonaker
  7. squirrel
    what year powerglide? if it's cast iron, no, but if it's aluminum, probably yes.
