Transmission question
Discussion in 'The Hokey Ass Message Board' started by erlomd, Dec 18, 2009.
  1. erlomd
    erlomd
    My buddy just bought a project and it came with a 4 speed mannual transmission that has GM
    20
    3799198
    J2861
    and a bunch of other numbers on it. Anybody have a clue what kind is it?
  2. mart3406
    mart3406
    from Canada
    Is the case iron or aluminum?
    Mart3406
  3. A pic would tell for sure
  4. erlomd
    erlomd
    <table style="width:auto;"><tr><td>[​IMG]</td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From Hot rod Pics</td></tr></table>
  5. squirrel
    55-66ish Chevy non-synchro 3 speed. Probably from 1961 from the casting date you posted before
  6. erlomd
    erlomd
    iron
  7. squirrel
    I'm not sure how you'd get 4 speeds out of that trans, either.
  8. What he said. It's not a 4 speed and will most likely blow up the first time you get on it if you have any kind of horsepower.
  9. Torkwrench
    Torkwrench
    Yeah, the date code looks like a 1961, but the tailshaft housing is from a 55 - 57 Chevy. There isn't any tailshaft motor mount. It was probably pieced together from a couple of different transmissions.
  10. erlomd
    erlomd
  11. erlomd
    erlomd
    can any body recommend a transmission then, or modify the one he's got? my buddys building a 392 blown Hemi with around 400hp its a 40' dodge pick up. the rear end is housing 3:73 gears or so (maybe a little less ratio) he wants it to handle the power and be able to cruise on the freeways with ease...so Im guessing this non-synchro 3 speed aint up to speed!
  12. squirrel
    or it's from a truck, they used a bellhousing mount thru 1972
    As for transmission recommendations....what does he have for a bellhousing/adapter?
  13. erlomd
    erlomd
    As for transmission recommendations....what does he have for a bellhousing/adapter?[/QUOTE]
    he dosent have one yet, so...anything goes. but manual is preferred
  14. Big Block Bill
    Big Block Bill
    Looking at the photo, that looks like a non syncro 3 speed, via '55-'56-'57 chevy because of the long tail. '58 and later were short tails and might have had a tranny mount, I think the motors went to side mounts by 58 also. Just testing my memory.......
  15. fordcragar
    fordcragar
    from Yakima WA.
    Shift it easy and don't get on it; it should last a long time.
  16. farmer12
    farmer12
    For (manual) adapters check out Keisler Engineering. good luck
  17. nzjkb5
    nzjkb5
    from Tennessee
    Yes, Keisler Engineering has adapters to connect the 392 Hemi to late model transmissions. They sell a TKO 5-speed that would handle the power no problem, and they might be able to set you up with their T45RS 5-speed tranny that is good up to 425 lb.-ft. and has overdrive but costs less. But if you want to go with a 4-speed they can sell you the adapter and bellhousing.
    http://www.keislerauto.com/ or 865-609-8187.
  18. George T G
    George T G
    If you don't have a ton of $$ for new stuff like a Keisler rig look for a 833 Mopar 4 spd and bell and get the spacer adopter for the 392 to Mopar bell.
  19. burnout2614
    burnout2614
    had one of those in a 60's c10 6 cyl, Broke it more times than I can remember. Could remove it "rebuild" it and put it back in just under 3 hrs. Had to drive it home in reverse several times. fun times
