transmission question
Discussion in 'The Hokey Ass Message Board' started by evobuilder, Jan 20, 2014.
  1. evobuilder
    evobuilder
    I have a th350 in my little coupe and it does something really strange (since I bought the car, its not a new problem), or maybe its normal, so I thought I would ask.
    When its cold, and I fire it up, and shift into reverse or drive.... it takes up to 30 seconds before the car starts moving. If I give it some RPMs it will start moving. When it is hot, it shifts fine, downshifts fine, etc. Now.... I know NOTHING about transmissions, but I know that this doesn't seem to be normal. Also.... its leaking like a stuck pig shot by an AK47, I am going to drop it out and replace all the gaskets, but don't se why that would be the culprit (and yes, I keep fluid in it).
    Any ideas? When I drop it do all the seals, should I consider having it rebuilt? Could this just be how it is (maybe due to a shift kit or a higher stall coverter)?
  2. Sounds exactly like a low fluid problem.
    Text book actually.
    There could be other issues but I usually start at the most simple.
    Any chance you leak enough to cause this problem?
    Is your dip stick accurate?
    Maybe the converter is draining and the excess fluid leaks out. Then the Trans needs to refill the converter before you get moving?
  3. Hnstray
    Hnstray
    from Quincy, IL
    ^^^^^^^^This sounds like it could be your problem.
  4. evobuilder
    evobuilder
    I think I will get all the leaking issues resolved first. Its leaking from soo many places, its hard to tell what is leaking and what is just catching fluid as it runs down the trans housing.
    The worst part is that I have replacedpan gaskets several times, but it is still still leaking from the pan, it is leaking from the shift locator hole, possible from the cheap *** billet dipstock (that no, I have no idea if its accurate) and from the trans cooler. It's not leaking quarts, but it is leaking enough to be a real issue.
    Its time for a professional to have a go at it.
  5. dana barlow
    dana barlow
    from Miami Fla.
    Likec 31vick said, I'm going to add a little,the f****** check an fill tubes that are aftermarket chrome **** an leak at the O ring. If the conv. seal is bad u need to do it as well as the pan gasket and shift shaft seal too
  6. evobuilder
    evobuilder
    If anyone in Seattle area knows a good trans shop... let me know
  7. Get the steel core pan gasket.
    Flatten the pan holes and don't over tighten it.
    The shift lever seals are a 5 min job with the right tools.
    The dipstick can be a ***** but if the converter is draining and over filling the pan you may never get the dipstick to that level of positive seal.
    The tail shaft is pretty easy to swap.
    Your cooler is just plumbing basics to fix leaks.
  8. 56sedandelivery
    56sedandelivery
    My guess would be the lip seals are "hard; when cold they're not very pliable, but get softer as the trans heats up. You can toss in a can of Trans-Medic, or whatever brand your parts store has. The chemicals in it soften the seals, making them seal better. It may be a temporary fix, but it will give you an idea about what needs to be done. Since you're going to be doing a re-seal, the pan will be off;if there's a lot of metalic sludge in the bottom of the pan, a rebuild may be the best thing to do. There's always some stuff in the bottom of the pan, unless you change the fluid often, I'm talking about more than just a couple of built up spots of metalic sludge. Butch/56sedandelivery.
  9. saltflats
    saltflats
    from Missouri
    I am guessing the hard lip seals in the clutch drums. If you are going to remove the ****** I would have it rebuilt.
  10. evobuilder
    evobuilder
    soo.... looks like the motor and trans are coming out. Whoever built the car made it so you cannot drop the transmission (there is a welded-in cross member in the way), so motor and trans are coming out.
    Looks like I will be doing gaskets and maybe a rebuild on both now.... **** howdy, guess I am digging into this deeper than I thought. Thank god its winter, I have some time to do this.
  11. d2_willys
    d2_willys
    from Kansas
    You say it leaks bad. Have you checked (with fluid topped off) the 2nd gear ac***ulator cover o-ring. These things go bad and won't leak unless you are driving.
  12. Mike Miller
    Mike Miller
    Your recurring pan gasket leak could also be the dipstick tube O ring seal.
  13. McGurk
    McGurk
    from Mid West
    Torque converter drain back. Numerous causes but, most common is valve body to case seal has been compromised.
  14. txturbo
    txturbo
    If it's not due to low fluid level, then it's morning sickness. Caused by hardened o-rings and seals due to age. A quick fix is to buy some TransX. It will soften up all the rubber parts and the problem usually goes away. I have a 66 impala that I put a 700 trans in that had this problem. Every spring I add some transX and it's good for the rest of the year. One of these days I'll be swapping in a different motor and I'll fix it right at that point.
  15. hoop98
    hoop98
    from Texas
    I was a Transmission tech before I started driveability. As the guys said above it's usually hard seals when you have this issue. The mechanic in a bottle may be a temporary fix but usually when the seals are hard, the bushings are worn and clutches.
  16. deucemac
    deucemac
    As mentioned, it sounds like "mornimg sickness" In first gear the forward and low/reverce clutches are engages. In reverse the low/reverse and high/reverse clutches are engaged. If the piston seals harden on the low/reverse clutch piston, you will have what is called a "late engage" until the seals heat up and become soft. Trans X is a good band-aid repair but the hand writing on the wall says that the trans will need to be repaired in the near future.
  17. evobuilder
    evobuilder
    ok, so here is the question.... do I rebuild, which is obviously time to do.... or just order another another one from Summit and sell mine as a core for someone else. Its crazy how cheap new ones are, but I can get one from Summit for 600-700 bucks. I am just wondering what makes more sense.
    Or I am better off just taking to a trans shop and have them go through it?
  18. Hnstray
    Hnstray
    from Quincy, IL
    If you have a reputable local shop, that is who I would prefer. The primary reason being, if there are ANY glitches with the rebuilt ****** you have someone to turn to for advice and ***istance. That, in my opinion, is worth something.
  19. X2 what he said ^^^
    The "If" part needs satisfied first though.
