Transmission Swap
Discussion in 'The Hokey Ass Message Board' started by Adrian Rollini, Oct 7, 2011.
  1. Adrian Rollini
    Adrian Rollini
    I have 62 Ford Falcon with a two speed transmission. I want install a 1964 Mercury Comet 3 speed manual transmission. I plan on buying the Mercury drive shaft, and pedal linkage as well. Do I need to change the gear ratio in the rear end with the different transmission, or will the stock Falcon rear end work?
  2. squirrel
    The two speed and 3 speed transmission both have the same 1:1 high gear ratio. You'll get a better low gear ratio with the 3 speed, but you won't have the advantage of a torque converter. My guess is it will work ok with the existing rear gears.
  3. Adrian Rollini
    Adrian Rollini
    Great to hear thanks man!
  4. George
    George
    You might look in the ref books & see if the manual cars had a stronger axle. Aspen/Volare(I know, diffrent cars) with 318 & A/T had 71/4 axle while the 225 6 cyl with manuals had the stronger 81/4 axle.
  5. sdg
    sdg
    All the 2-speed auto Falcons I've seen (a handful) have had 3.50 gears, including my wagon. I don't know what ratio the 3-speed manuals came with, but as I'm pretty sure the C4 (3-speed auto) cars came with a 2.9 or 2.8 something-ish ratio.
    My wagon was converted to C4 by a previous owner.... With the 3.50 rear end, it's snappy on take off (the snappiness goes away fast) and has good torque for general driving. It's wound a little high going down the freeway but trucks up grades with ease. Even with the whole family and all the junk that goes with them, it'll climb a good grade at 60-65 and still have pedal left.
    Aside from giving up some fuel economy, I'm really happy with the combination.
    Sorry for the long winded response. Hopefully some of that helps.
