Technical Transverse Parallel leafs & control arm.
Discussion in 'The Hokey Ass Message Board' started by Doug Wallis, Jan 20, 2025.
  1. Doug Wallis
    Doug Wallis
    Has anyone ever seen this suspension before? It's on a 1930 Vicky. I can not find it on anything. Obviously the control arm fights the springs trying to twist when braking. Maybe it was from a tractor? Any help is much appreciated.
    Just.dale likes this.
  2. 49ratfink
    49ratfink
    gotta be off some foreign car. what does the rest of the car look like?
    SS327 likes this.
  3. Happydaze
    Happydaze
    Doesn't appear to have shocks. The uprights and top arms look to be manufactured, not home brewed. Double transverse leaves!
    Chris
  4. Just.dale
    Just.dale
  5. Weedburner 40
    Weedburner 40
    Looks similar to 50's era Willys two wheel drive. The Willys only had one leaf spring though.
    mitch 36 likes this.
  6. RodStRace
    RodStRace
  7. Opel had a front suspension like that, only a single leaf though, my friend has one on a '48 Anglia from a '69 or so Opel Cadet. If memory serves me, there was a thread not to long ago about a suspension system kinda like that. Some brand of 30's orphan I believe. But maybe not .Mitch
    THE FRENCHTOWN FLYER likes this.
  8. Doug Wallis
    Doug Wallis
  9. Doug Wallis
    Doug Wallis
    Yes, it's stiff. Without pot holes it's not overly stiff. This car isn't underpowered which makes it a handful. I followed those links and every one I can.
  10. Doug Wallis
    Doug Wallis
    Everything looks manufactured. Obviously the brakes and rack and pinion are not original to whatever it was.
    No shocks. It (chassis/body) was built in Indiana about 25 years ago. Boxed, Z'd, 4 link, 4 wheel disc, stainless floor pan, etc. I am going to have to change the front suspension out or do some other custom mods to make it safe at what it does.
  11. It looks to have a pretty long wheelbase in he pic you posted. Is there any indication that the frame has been altered from the stock length? Knowing the original wheelbase might help narrow down your choices.
  12. Doug Wallis
    Doug Wallis
    Thanks, yes it's definitely lengthened. 124inch wheelbase. After the engine it changes to full custom 3x2 tube with a triangulated 4 link.
    I'm around 500hp now and will probably make 600 to 650. The crude measured frame width at the front suspension looks stock to a 1930 model A. I may go non traditional and I do need a tighter turning radius and good brakes. Willwood master cylinder now. I'd like willwood all around.
    I really like the unique approach on this car but with HP it's not right.
  13. RodStRace
    RodStRace
    @Doug Wallis It probably doesn't matter, since the car looks and sounds like it was built in the past couple decades, not HAMB era, but where is your general location? It might help knowing what raw material was available to put this together. Judging from the info so far, it sounds like a 30s to 50s front end from a Euro or orphan manufacturer. The number of leafs in a pair of springs seems to indicate a fairly heavy duty donor.
    Doug Wallis likes this.
  14. RodStRace
    RodStRace
  15. RodStRace
    RodStRace
    BTW, you might want to edit the title to get more eyes on this.
    Transverse
    milwscruffy likes this.
  16. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Yup, We usd a similar GT front suspension on our '48 Anglia build.
    alanp561 and Doug Wallis like this.
  17. Doug Wallis
    Doug Wallis
    I believe it was built in Indiana. I'm in Fl.
    RodStRace likes this.
  18. 1971BB427
    1971BB427
    from Oregon
    If the front suspension wasn't really stiff those springs would likely bottom against the frame rails! They look pretty close now, so softening it up by removing a few leafs might cause springs to hit the frame.
