traverse rear spring crossmember for 1932
Discussion in 'The Hokey Ass Message Board' started by brady1929, Jul 20, 2008.
  1. brady1929
    brady1929
    does anyone else make a traverse rear spring crossmember for a 32 ford frame (similar to so cal), other than so cal? the crossmember used for mounting a 40 rear spring. i want to know all options available to me. theirs is about $128. thanks
  2. trevor
    trevor
    i think Pete & Jakes has one like that , but it doesn\\\'t look like it would be too hard to make your own with some DOM tubing and some flat plate
  3. VAPHEAD
    VAPHEAD
    I use the Pete and Jakes on alot.
    But it would be very easy to make for yourself.
  4. Very easy to make.
    Here I used 40 ford front spring in the rear.
  5. roundvalley
    roundvalley
    Go to the Alliance= Owens Salvage. Bought a '35/'40 rear NOS from Bob. Was less than Pete Jakes and let you use the straight spring and get away from the curved '32.
    Join the Alliance!
  6. The problem with using a stock 40 rear x member the car will sit a mile high.
    When they are used they are often cut to flatten them out some, but still wont be as flat as a straight piece of tubing.
