Technical tremec in my Impala
Discussion in 'The Hokey Ass Message Board' started by nwbhotrod, Aug 29, 2014.
  1. nwbhotrod
    nwbhotrod
    from wash state
    looking for info on installing a Tremec tko in my 1962 chevy impala nods to the floor shifter location Thanks for the help
  2. need louvers ?
    need louvers ?
    Should pretty much just bolt up. My guess would be the forward position of the rearmost **** location should do the trick, but at worst you have to a mid shift kit. I just did a mid shift for a client a couple of month ago and it took all of 1 hour to install. 'Bout all you can do is put it up there and see. I'll tell you what though, you'll find it's the best money you have ever spent!
    jeffd1988 likes this.
  3. aussie57wag
    aussie57wag
    from australia
    If its just a cruzer id keep the 3speed column shift with an overdrive. Same end result as the tremac but way more old school cool, and less gears to mess with.
  4. nwbhotrod
    nwbhotrod
    from wash state
    Thats what i have been told but also told i may need to make some mods the the floor
  5. nwbhotrod
    nwbhotrod
    from wash state
    its a factory four speed car i want use fro cross country trips
  6. aussie57wag
    aussie57wag
    from australia
    Oh that sounds more understandable and it shouldn't upset the old school looks. Cool.
  7. Relic Stew
    Relic Stew
    from Wisconsin
    There are 4 different shifter positions possible.
    Looks like 2nd from the back matches GM transmissions.
    Looks a little wider and flatter across the top, so the trans hump may need m***aging.
  8. Russco
    Russco
    from Central IL
    All I can say is do it! I agree the forward rear position should be about right they are a bit broader and bulkier than the 4 speed but you will LOVE it. I'll likely never use a Muncie again!
  9. nwbhotrod
    nwbhotrod
    from wash state
    I am not to worried about the shifter what about pilot bering and thowout bering and the floor trans tunnel
  10. Russco
    Russco
    from Central IL
    The GM TKO600 I used, used all readily available pilot and release bearings, pressure plate and disk for GM stuff. I went to a local Clutch & Brake wholesaler and they had everything in stock. I frikking love this transmission too. I got the close ratio OD and am running a 3.50 gear. I cant say for sure on yours but I imagine the tunnel will need to be enlarged slightly width wise. Mine is in a '40 coupe and it almost fit with no mods to the floor.
  11. nwbhotrod
    nwbhotrod
    from wash state
    What abot the x frame and tans cross member
