Tremec tko 5 speed adapter question
Discussion in 'The Hokey Ass Message Board' started by v8creator, Oct 19, 2010.
  1. v8creator
    v8creator
    Does anyone make a adapter that will put a tremec tko 5 speed for a ford to a chevy small block
  2. 41PICUP
    41PICUP
    Try Wilcap, in S. Calif.
  3. Hi!
    Hi!
    from SoCal
    The Tremec TKO will bolt to a standerd bell housing. A ford TKO will fit a ford. Chevy TKO to a chevy. The only adapter for TKO is ford trans into a chevy and its a spacer for the longer input.
  4. Jmountainjr
    Jmountainjr
    Lakewood makes a bellhousing that will put the Ford TKO behind a SBC. It's a big can that will take a big flywheel and is a bit deeper to take the longer Ford inputshaft. In a big car like a '55, the size isn't an issue. In a '28-'32 it can be. I've been down that road. The easy way would be to sell / trade the Ford TKO for a Chevy TKO and have more options. Having said that, I think Forte's in MA does sell the spacer plate as mentioned above to put a Ford TKo behind a SBC. It was engineered for the Camero's before the Chevy TKO was available. I'm not sure if it lays the tranny over, or not. Give them a call. They do a lot of Tremec conversions and are usually good on the phone.
  5. ems customer service
    i put tko behind my sb ford even with all the so called correct parts it was a real pain everything seemed to be a problem.
