Tri-Five Chevy front motor mounts????
Discussion in 'The Hokey Ass Message Board' started by Rusty, Nov 11, 2010.
  1. Rusty
    Rusty
    Okay doing a basic install on a 57 chevy putting a V8 using stock front mounts, We came across 2 different length studs for the rubber biscuits to slide through, One is rite at 1" gap between the rubbers an the other is 2.5" between.
    So were 6 cylinder and V8 different lengths? I did some looking around at vendors and it appears there is only one part number and the pciture look like the one I am using.
    the whole reason I started researching this was because the tie rod was hitting the drain plug on a stock 283 Oil pan when turning all the way each way. raised a flagsince they came with 283's.
    I looked at a different oil pan and the one on the 283 is 2" wider front to back that the other I have. that would give plenty of clearance.
    heres a couple shots of the rod / bolt I am refering too
  2. Max Gearhead
    Max Gearhead
    from Wisconsin
  3. Rusty
    Rusty
    If they were different lenghts then why do they only offer the short length now?
    Was V8 the long one or vise versa
  4. If the picture on the right is the longer of the two, it appears longer than the one my parts book shows for the v8. H&H Cl***ic Parts Catalogue.
  5. Rusty
    Rusty
    Yes the pic on the right is the long one. the one istalled is hopefully the correct one?????? Based on the catalogs,etc. If the picture is rite?
  6. I think you want the short one for the v8.
  7. Rusty
    Rusty
    thanks to the top for the morning crowd, if not I am gonna set it up,
  8. Rusty
    Rusty
    anyone else
  9. BulldawgMusclecars
    BulldawgMusclecars
    If you can wait til later tonight, I'll check on my '57. It still has the original mounts on it.
  10. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Went and measured the mounts on a v-8 '55 im working on in the shop and it has 1" between the bisquits.
  11. Rusty
    Rusty
    thanks guys, thats perfect
