Technical Tri five frame application
Discussion in 'The Hokey Ass Message Board' started by capnmike, Nov 14, 2025.
  1. capnmike
    capnmike
    I've worked on countless old Chevys with closed driveshaft. I read somewhere that the early to '54 closed driveshafts/rearends will drop out and a 55-57 rear end/springs is a direct bolt in. At 80 yrs old I don't want two bays of parts that do not interchange. Besides hearsay, is there anyone who has done this swap and can 1951 Chevrolet Fleetline.jpg give me a qualified answer? I have a '51 Fleetline and a '54 Sedan Delivery, either would make a nice cruiser. Thanks for any "qualified" answers. Capn
  2. Budget36
    Budget36
    Mark @Moriarity , explained it once before. If no one else chimes in, he’ll let you know.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The 5 6 7 rear will swap in with new locating hole drill to center rear property. Never ever have I heard about springs swapping over.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Thinking about it, isn’t 54 springs 1 3/4” wide vs 2” wide for the Tri-Fives.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup use your stock leaf springs. Simply drill a new center bolt locating hole in the spring pad to move the rear end back 1 1/2 inch. Then it is a bolt in swap. Use the u bolts and lower shock mounting plate for a 55-57
  6. jimmy six
    jimmy six
    They are a direct bolt in. The last one I installed a 1956 in a 1950 and only made one change. On the 55-57 spring perch you need to drill an additional hole as far forward on the perch as you can for-the spring bolt head to center the wheel in the fender opening. It needs to move back. I found the drive shaft shorter than I liked an bought an extended yoke that circle track guys use so I didn’t need to have a drive shaft made. This depends on your trans.
    Also the e brake worked fine if you’re keeping a 6 cylinder.
    There are some bellhousing options if your are using the 6 for a later transmission with an open tail shaft.
    I would not use a 55 as the outer bearings were a little different.
    Good luck.
    chevy57dude likes this.
