i think my manual steering box lube has leaked out over the years. anyone know capacity and weight to use?
1957 service bulletin "Lubricant recommendations for 1955-57 p***enger car steering gear have been changed to discontinue the use of ‘Multi-Purpose’ lubricant and recommend in its place ‘Ch***is Lubricant’. Coincident with the change in lubricant recommendations, service personnel are advised that the steering gear lubricant level should be maintained 3/4-inch below the filler plug hole instead of level with the filler hole as previously prescribed. The reduced level lessens the possibility of lubricant being forced out of the steering gear box during the pump action that results from fast turning of the steering wheels." Penrite is the closest, 90W will just run out, next is CV Joint grease like SWEPCO 101 Moly Grease.
You do not use ch***is grease in the s/box. It channels and causes hard steering and eventual premature wear. See hoop98 post above. The penrite steering gear lube is a "semi fluid grease" . I use it in my truck , I think it is great . It is best to warm it to aid its flow. OR , just mount a funnel in the s/box fill hole and let it drain in at its own pace . It will take a long time Regards
Pg 24-25, it's for steering boxes that call for "Steering Lube" Pennrite states: "A self-levelling, high viscosity lubricant containing non-corrosive extreme pressure additives. Ideal for veteran and vintage steering boxes. Not recommended for rack and pinion steering." http://www.restorationstuff.com/pdf/RestorationSupplyCompany.pdf
John Deere "Corn Head Grease" It is self leveling, and is cheap and readily available at their Distributors.
Wouldn't you know... it says on it, made in UK. Leave it to the Brits, can't fix the leaks, so they invent a lube that almost does not leak. I love it. I use Penrite in a couple of my oldies that used to leak 90w... Problem solved. A little 'pricey', but not much is needed.
John Deere Corn Head grease isn't really all that special. It's just a NLGI grade 0 grease. You should be able to fine that at a lot of different places.
From the 55-59 GMC Maintenance Manual and Texaco Multifak EP greases are available in three grades: NLGI 0, 1 for better pumpability at low ambient temperatures.
That 90w is gonna leak, but it'll certainly lube up your box.. So dont be surprised to find oil in your drive way and all on the underside of your car. I'd follow up with typical all purpose grease and just pump it into your box.
I use my grease gun and fill- er up, with whatever I use to grease the front end with. Works for me. Also change the seal on the box where the shaft comes out, be careful not to hurt the seal on the splines. I wrap the shaft with paper to protect the seal during installation.
