Tri five wipers
Discussion in 'The Hokey Ass Message Board' started by onebadrambler, May 20, 2011.
  1. onebadrambler
    onebadrambler
    A friend of mine just bought a 57 chevy and found the wipers disconnected after hooking the wiper`s back up they park in the vertical position????The wipers are a vacuum set up.Any suggestions.........
  2. 302GMC
    302GMC
    from Idaho
    Pull the motor & park the blades ... then re-install the motor.
  3. onebadrambler
    onebadrambler
    That`s It!!!Thank`s you just saved me alot of aggravation....
  4. krylon32
    krylon32
    from Nebraska
    Newport Engineering
  5. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Switch over to electric wipers. Vacuum wipers are the pits.
  6. brian55lvr
    brian55lvr
    from ma
    what you do is push each wiper down----on the base of arm----it has a clutch mechanism--and you can reset each on individually
    and yes---def switch to electric
  7. If they are swiping the gl*** in the right place, then there is a problem with the motor. Vacuum wiper motors are simple and usually only need some heavy grease in them to help them out. Electric is the way to go, but then most guys leave their baby home in the garage when it's raining, so why spend the money?
  8. Jimm56
    Jimm56
    amen!
  9. 325w
    325w
    I'd take both blades and arms off then run the wipers. When they parked I'd set the arms back on in the park position. may have just been installed incorrect. jus sayn
  10. NINE INCH
    NINE INCH
    If you decide to switch to electric...check RAINGEAR. nice unit from Port Townsend, Washington. Google it.
  11. onebadrambler
    onebadrambler
    Problem solved the cables were installed backwards.the figure 8 was on the right side and oval on the left i r/r the cables and reinstalled them with the figure 8 on the left and oval on the right perfect(also added an electric motor) http://www.jalopyjournal.com/forum/images/smilies/smile.gif
