Hot Rods Tri Power, 350 Chev in '41 Ford. No place for coil???
Discussion in 'The Hokey Ass Message Board' started by ford350, Apr 3, 2010.
  1. ford350
    ford350
    from Wi.
      236 KB
  2. mart3406
    mart3406
    from Canada
    How about inside the car - on a bracket under the
    dash somewhere, or mounted on 'interior side' of
    the firewall??? You could drill a small hole (or use
    an existing one. already in the firewall) to run the
    high-tension lead from the coil to the distributor
    cap. Just be sure and use a grommet on the wire
    where it p***es through the firewall to protect it
    and keep it from from getting cut or chafed.
    Mart3406
  3. ford350
    ford350
    from Wi.
    Thanks but I have made up my mind that I will not drill any holes in the firewall after I welded all the holes and re painted it along with the rest of the sheet metal.
    In my Accell spark plug wire box I found out that the coil wire is 36" long and that will be enough to mount the coil over on one of the inner fender panels.
