Tri-Power Carb Spacing??
Discussion in 'The Hokey Ass Message Board' started by Daves 5898, Aug 26, 2009.
  1. Daves 5898
    Daves 5898
    1958 Chevy Carb centers same as Olds J-2 6" ?? Looking for 3 duece oval air cleaner for Rochster 2G,s 6" center to center. Thanks Dave
  2. MilesM
    MilesM
    Yes, my factory 348 cast iron tri power is 6" spacing
  3. k.c.
    k.c.
    Try Vintage Speed.
  4. I made my air cleaner from sign aluminum and spacers of 3" aluminum driveshaft tubing, 240z air filter.
  5. carbking
    carbking
    When the Ford enthusiasts reproduced the oval air cleaner for the Ford Holley 3x2 and 2x4; they also thoughtfully reproduced it with the botton UNPUNCHED! Nice looking air cleaner, and they also reproduced the element, so new elements are readily available. You can punch the bottom for your own custom configuration, if function and not originality is your goal.
    Jon.
  6. tommy
    tommy
    I got this cheap one for 50 bucks on Ebay. It's a new universal dual quad set up.
    3 of those cheap 2bl A/C bases and a flat piece of sheet metal with the appropriate hole spacing.
    I bead blasted off the black. I like it considering the price and the fact that it's not a faithful 406 clone.
    I was all excited to get 3 mid 60s aluminum flat sided A/Cs for trips. They would have been perfect for my early 60s theme. When I got them they were too wide for the Edelbrock spacing. I think there were made for the Pontiac carb spacing. I was heart broken.:D
  7. Daves 5898
    Daves 5898
    Thanks Guys for the info now to find a chevy one! Daves 5898:).
