Tri-power linkage
Discussion in 'The Hokey Ass Message Board' started by jdubbya, Jan 31, 2004.
  1. jdubbya
    jdubbya
    I am close to getting my tri power ready for installation on my SBC. I am running a set of 60's Pontiac Rochesters, and plan to us a progressive linkage. I am interested in knowing where anyone bought their linkage, or linkage components? I have been told that it is best to use the bearing style linkage, to keep from binding. Any info here would be great, this is my first experience with a tri power set up, and I am trying to minimize my headache. If anyone has a linkage set up for sale that would work with my carbs, I may be interested also.
    Thanks in advance - Joe
  2. Jimv
    Jimv
    I made my linkage with heims,I used all primary carbs so i ran a rod from the 1st & last carb down low.Then used the center carb to pull with a cable & ran a short rod to the front carb on top with the rod going thru a tube & a collar in front & behind the tube with a space in the front.When you step on the gas it lets the center one open till the collar reaches the tube the it opens the other 2!!
    I tried posting a picture but its too big, i'll e-mail it to you.
    jimV
  3. Jimv
    Jimv
    "thirtycoupe" shrunk it for me.
    Thanks Mike
    JimV
  4. manyolcars
    manyolcars
    [ QUOTE ]
    I made my linkage with heims,i ran a rod from the 1st & last carb down low.Then used the center carb to pull a short rod to the front carb on top with the rod going thru a tube & a collar in front & behind the tube with a space in the front.When you step on the gas it lets the center one open till the collar reaches the tube the it opens the other 2!!
    [/ QUOTE ]This is what I did, notice I altered Jims quote. Why pay $50 for something I can make for $3? ( the cost of the heims)
  5. Fat Hack
    Fat Hack
    from Detroit
    Jimv's set-up is similar to what my buddy ran on his small block Ford tri-power set-up, and it worked well. (He also made his linkage with steel rods and heim joints.)
  6. Turning on the light.... [​IMG]
  7. tommy
    tommy
    My home made attempt.
  8. burger
    burger
    Hey Tommy,
    What's that fuel log? It's pretty neat looking.
    Ed
  9. tommy
    tommy
    I made it out of tubing to resemble the early 60's Ford fuel manifolds. 3/4 tubing with the end welded shut. 5/16 steel tubing for the ******s...a little fileing and some powder coating. Thanks for noticing.
  10. That is quite cl***y, Tommy.
    I really like seeing well-done home-made stuff.
    Especially something like your fuel log that looks factory, but ain't....
  11. jdubbya
    jdubbya
    Thanks alot for the pics, that will help me out alot. I too really like the fuel line set-up Tommy, I plan to do something of a similar nature to mine. -Joe
  12. du$ty
    du$ty
    where can you buy the little linkage arms on the carbs?
  13. manyolcars
    manyolcars
    [ QUOTE ]
    [/ QUOTE ]It is so easy to make, why consider spending your money?
  14. Paul2748
    Paul2748
    I'll ad my thirds
  15. fuel pump
    fuel pump
    from Caro,MI
    http://www.hotrodcarbs.com/
    Check this place out. I used their stuff on my Roch tri power on my '32. fab's got it now and I'm sure you could check it out if ya asked real nice [​IMG]
  16. tommy
    tommy
    I pick them up at flea markets. Somebody always has them on a card with a rod to connect 2 carbs. together. Most any supplier that carries flathead speed parts will have them.
    thanks for the compliment Jay. Like my tag line implies 99% of the people don't see the details. It's the one percent that do that make it all worth the effort.
  17. Shiva69
    Shiva69
  18. du$ty
    du$ty
    [​IMG]because i made the rest of my car...i think ill be ok buying the little arms.
  19. Jimv
    Jimv
    Heres a drawing i made of my linkage, hope it helps
    JimV
  20. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    The only thing is JimV, with your setup the front and rear carbs wont be opening all the way at full throttle, will they?
  21. flt-blk
    flt-blk
    from IL
    Kartbreaker,
    Charlie Price at Vintage speed ??Vintagespeed.com???
    If you look through his website there are great pictures and all the extended arms for the ****erfly plates, linkages, stoppers, etc.
    You can also get the progressive linkage from speedway, around $50 I think
    TZ
  22. chickenridgerods
    chickenridgerods
    from DSM, IA
    [ QUOTE ]
    [/ QUOTE ]
    Depends upon the points where the linkage connects to the arm on the 1st and 3rd carbs when compared to the location on the arm of the middle carb.
  23. Jimv
    Jimv
    I used a hole in the front carb that is lower in the arm so its a smaller arc it has to move.They do open all the way.
    jimV
