tried to id this trans but cant seem to find it - out of a chevy c10 with 250
Discussion in 'The Hokey Ass Message Board' started by neverwinter, Nov 16, 2012.
  1. neverwinter
    neverwinter
    hey all here are the numbers i found on the trans which appears to be a saginaw 3 or 4 speed.
    on the case: M 3962645
    beneath that is: E 6 1
    beneath that is: 28 or 26
    on the tail shaft is: 3873886 GM 14
    this came with a 71 c10 and 250 i got and am trying to sort if i can use it in a 41 chevy coupe with the 250. thanks as always for any insight.
  2. Probably too wide to fit under a '41 Chevy no matter what it is. An S10 4x4 rear should be easy to find and will fit without a lot of hassle.
  3. PackardV8
    PackardV8
    If it has two shift levers, it's a Saginaw 3-speed. Three-levers is a 4-speed. Both good medium duty trannies.
    jack vines
  4. neverwinter
    neverwinter
    yeah i finally found the info and i believe it is a 3 speed. i didnt see any grooves on the input shaft so not sure what the gear ratios are. i can either drop this whole thing into the 41 or drop about 300 and get the adapter and cluth setup for the t5 i have. i dont mind spending the money if its going to make a whole hell of a lot better - i just plan on around town driving with the occassional long cruise. 300 for a 5 speed isnt going to break the budget but if what i have in the 3 speed will be close to as effective i may just go with it and sell off the t5 or keep it for a later day. any thoughts?
  5. Mr48chev
