Technical Trim Clip Help Needed
Discussion in 'The Hokey Ass Message Board' started by kustomfordman, May 7, 2024.
  1. kustomfordman
    kustomfordman
    I am trying to install the tail fin trim on the '59 Ranch Wagon but having difficulties with the retaining clips. The clips need to be installed on the body first and then the trim is pushed onto the clips and the trim snaps into place on the clips as I understand it.
    The center portion of the clip on the body side fits into the hole and then by spreading the back side open, the body side of the clip in the hole will "****erfly" open and thus holding the clip in place.
    I have done this repeatedly with multiple clips and multiple holes but the clips will not stay in place. I have reshaped the portions that spread open hoping to get a bigger spread when the clip opens up to catch on the body, but no luck.
    Anybody see a problem with my approach or have suggestions. Its almost like the holes in the body are too big, but its all stock original. PXL_20240507_131941202.jpg PXL_20240507_132014559.jpg PXL_20240507_132054160.jpg
  2. BJR
    BJR
    Used clips of that type don't work very well, good luck trying to find some NOS ones.
    SS327 likes this.
  3. woodiewagon46
    woodiewagon46
    from New York
    I would give Restoration Specialties & Supply, 814-467-9842, and ask if they have new clips, that might be your issue. They also have a great catalog.
  4. BJR
    BJR
    Another option if you can't find new clips, is to drill holes and install the old clips with 2 pop rivets. One in each end of the clip with a small washer over the slot that the rivet goes through. I have done that when new clips were not available on other cars.
  5. kustomfordman
    kustomfordman
  6. kustomfordman
    kustomfordman
    Great idea! I will think about this approach. Thanks
    lothiandon1940 and Tow Truck Tom like this.
  7. abe lugo
    abe lugo
    you need pliers like these. [​IMG]
    or get some cheaper pliers and a grinder and make some.
    Also DC sells the version of these clips with screws
    You just really need like every other one. use some black body sticky on the left over holes.
  8. abe lugo
    abe lugo
    you can try to reach around through the interior and flatten front the other side while some hold something against the outside clip.
    also use the body sealer on these when they are in place otherwise you get water in the body.
    These also can be bolted in if you run a bolt and do the reach around to get to them with a nut, but have a helper!
    RodStRace likes this.
  9. abe lugo
    abe lugo
    I happened to have the windoe open and they have some through the DC cat. upload_2024-5-8_18-10-1.png
  10. bobss396
    bobss396
    There are actually THREE types of clips to hold that piece on. All of the usual catalog sites are wrong. Every single one just lists ONE clip for the whole piece.
    I agree on Restoration Specialties, if anyone would have it, it is them. Do you have the trim guide for the '59? I have one possibly in the garage, I'll look later.
    lothiandon1940 likes this.
  11. kustomfordman
    kustomfordman
    I do not have the trim guide. That would be a great help. I have all the original clips, but darn if I can see any difference in the two similar clips. I think the third clip is the on on the end near the reverse lamp which has a threaded stud.
  12. Stu D Baker
    Stu D Baker
    from Illinois
    Typically, long pieces will only utilize threaded T-bolts near each end of the trim. The rest of the clips are usually as shown in previous posts. If you are having difficulty getting the clips to seat tightly in the factory holes, I wouldn't hesitate to carefully "stake" them with a small pop rivet or screw.
  13. bobss396
    bobss396
    I will stumble out in a bit, I think I know where it is. Half the battle...
  14. manyolcars
    manyolcars
    bobss396 likes this.
  15. lothiandon1940
    lothiandon1940
  16. manyolcars
    manyolcars
    yeah, its not the money. I can make a bunch of them quickly and dont have to wait on shipping. Same with putting new tires on rims. I can do it at home a lot quicker than waiting in line at a tire store
  17. bobss396
    bobss396
  18. SS327
    SS327
    Or you can just run a stainless steel sheet metal screw through the center of the clip. It spreads open the tangs. I like to use some windshield ribbon around the holes too. It won’t harden or crack.
  19. kustomfordman
    kustomfordman
    I was able to get this sorted today. The good news is I was able to use most of the original clips and as designed. With enough body sealer on the clamping side of the clip the clips hold. I was trying to install them dry and then put the sealer over the top of the clip. You wouldn't think that the body sealer would make the clip hold better but it does. They are solid and the trim snaps into place. I had about 3 clips that I ran a self tapping screw thru the middle and then backed it up on the inside with a "U" nut.
    SS327 and Stu D Baker like this.
  20. bobss396
    bobss396
    Ford used some sort of red sealant on the clip installations. Some clips I got with trim, it was still pliable.
