Triple deuce help
Discussion in 'The Hokey Ass Message Board' started by 35fordrat, May 19, 2014.
  1. 35fordrat
    35fordrat
    Fired up my motor yesterday and got it running good and timed. The problem is when I shut the motor off. After a about a minute, the primary carb starts to leak from the tiny holes on either side of the carb in the base plate. See the picture. I also noticed that gas continues to slowly come out of the jets even after the the motor is shut of. Not a lot, just seeps. Anyone have any idea? ImageUploadedByH.A.M.B.1400527143.635354.jpg ImageUploadedByH.A.M.B.1400527160.637328.jpg ImageUploadedByH.A.M.B.1400527178.237111.jpg
  2. ghornbostel
    ghornbostel
    too much fuel pressure. Gas is probably getting by your needle and seat. Some of the Carter experts will probably log in with a good psi range. My webers leak all over the place above 3psi
  3. aaggie
    aaggie
    Install a regulator with a return line back to the tank. Set fuel pressure to 3.5-4 PSI. I am ***uming the floats are set correctly and the needle and seats are sealing.
  4. 35fordrat
    35fordrat
    Thanks for the advice! I have a Holley 12-804 fuel pressure regulator. It has 1 in port and 2 out ports...Can I run one of the out ports to the carbs and the other to the fuel tank as a return? ImageUploadedByH.A.M.B.1400547941.910509.jpg
  5. Yes, but one is the regulated port
  6. Copy of HAMB plus Engine 003.jpg Copy of HAMB plus Engine 014.jpg On my set-up, which is the same as yours, I run the right port to the carbs and the left one I've got a pressure gauge. You can use the port where I have the gauge and run a return line, although I've never needed one. I set the pressure at 4 p.s.i.
  7. lurker mick
    lurker mick
    Mine is set up similar to oldschool66's, set at 5PSI. I've run several multi-carb set ups & never used a return line.
  8. 35fordrat
    35fordrat
    Great thanks guys! Ok... So next is vacuum. I currently have the primary carb vacuum plugged. Do I need to run a line to it from the intake?
  9. vtwhead
    vtwhead
    I ran manifold vacuum on my 3x2 setup. Seems there is a lot of opinions on this subject. The 348 tripower ran vacuum from a hollow stud that was also used as a carb base stud on one of the carbs FWIW.
  10. ebfabman
    ebfabman
    Are you planning on running a PCV system?
  11. 35fordrat
    35fordrat
    Just so I understand... If my mechanical fuel pump is 8-10 psi and I use a pressure reg after the pump, won't the pressure be so great that it will need a return line?
  12. 35fordrat
    35fordrat
    Don't think so...I am using the original valve covers that have the oil fill cap breather hole in one of them and a breather hole in the other. I was planning on running breather caps like the covers are permitted for. The only vacuum I am using at the moment off of the intake, goes directly to the transmission. No power booster for the brakes. Bare w/ me guys... This is my first duel carb set up.
  13. ebfabman
    ebfabman
    If you like to tinker, you picked a good set up. The home brew tripower will require some attention to get right. One thing is for sure, its very gratifying when its dialed in. If you want to get the most out of driving light footed on a two barrel, you will need to also dial in your ignition with a good mech curve and a matched vacuum advance. There is some very good info resources on the net if you search it out. Where did your carbs come from? Are they three primary carbs or is the front and rear set up for true tripower?
  14. 35fordrat
    35fordrat
    Great advice, thanks! Both outside carbs are dumpers. I am running a Pertronix electronic distributor w/ mechanical advance. Do you have an thoughts on vacuum for the carbs?
  15. Jimv
    Jimv
    I run trips on mine with no regulator, I was told that Rochesters are OK with 8 psi.Strombergs need a regulator.
    when you say that its leaking past the "jets" do you mean the accelelater nozzles? Check for the little check ball in the port where the accel pump sits( should be in the bottom) & make sure you secondary ****erflies are closed tight.
    Take your ****** vacuum right off the manifold, not off the carb.And lastly check your float heights.
    JimV
  16. ebfabman
    ebfabman
  17. 26 roadster
    26 roadster
    Only vacuum on mine is off the center carb for pcv valve
  18. bgaro
    bgaro
    i had the same problem. messed with the float, installed the edelbrock version of your regulator and gauge. set that thing to 3 lbs, no return. worked like a charm.
  19. 35fordrat
    35fordrat
    So no return at all...Not even off of the fuel pump? I have no return out of my mechanical pump? Do you have a return off your pump?
  20. bgaro
    bgaro
    nope, no return at all, anywhere. i used the old corvette style that bolts together.
  21. 35fordrat
    35fordrat
    Yep that's the same mechanical pump I am using. Thanks man
