Triple-jointed driveshaft?
Discussion in 'The Hokey Ass Message Board' started by JonF, Dec 19, 2011.
  1. JonF
    JonF
    My donor car is a 1990 Lincoln MK-VII and I'm using a 8.8" rear out of an Explorer. Why does the Lincoln drivershaft have 2 u-joints on the end by the rear end?:confused:
  2. That's a double cardan joint. It is a type of constant velocity joint.
  3. Mr48chev
    They let the driveshaft in the Lincoln run a little smoother at least in theory. That setup isn't needed in a hot rod though unless it just happens to be the perfect length for the installation. Among other things they are somewhat expensive to repair as compared to a driveshaft with a joint on each end.
  4. JonF
    JonF
    Thanks for the education, guys.
  5. sunbeam
    sunbeam
    And they are a pain to repair.
  6. 40FordGuy
    40FordGuy
    And, a lot of them cannot be repaired,...what is done is to cut the bad one off the shaft, and weld on a new item. The shaft is re balanced, and you buy a "rebuilt driveshaft". I learned that when I owned a 68 Caddy.
    4TTRUK
