Triple-Quad carb setups - info or pics anybody???
Discussion in 'The Hokey Ass Message Board' started by mart3406, Dec 18, 2009.
  1. mart3406
    mart3406
    from Canada
    'Triple-Quad' carb setups - info or pics anybody???
    A bunch of years ago at an ouitdoor car show
    and swap meet, I saw a Model A coupe with a
    a 6-71 blown SBC. . What was unusual about
    it., was on top of the blower, instead of the usual
    'single 4-bbl' or 'dual-quqd' set-up, the car had
    three..count 'em, three, AFBs! The car was a
    street driven rod too, not a show car. I waited
    around, hoping to run into the owner to pick his
    brain about his triple-quad set-up, but never
    did manage to meet up with him. I've never
    seen another triple-quad set-up before or since
    either and was wondering if anyone here has
    some 'real world. experience with a set-up like
    this?? Also, does anybody have pics from either
    'back in the day' or current, of cars running
    'three 4-bbl' carb setups???
    Mart3406
  2. You Mean like on the Moonkist T-Bucket?
  3. oldspert
    oldspert
    from Texas
    In 2006 at the Oldsmobile club Nats, there was a 66 Cutlass that had four, yes four, Quadrajets. One pair of venturies for each cylinder. I don't think he ever got it to run correctly on the road but that som' bitch would sure wind up qiuck. Called it the QuadQuad
  4. mart3406
    mart3406
    from Canada
    Hmmm??? Ya' think it was just tad
    over carbureted, maybe???:D:D:D
    Mart3406
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Several years ago, High Performance Pontiac magazine featured a '66 GTO with three AFBs on a modified tripower intake manifold.
  6. panic
    panic
    When will it work:
    1. when not all the carburetors are actually doing anything (linkage not connected to throttle shaft, secondaries never open, manifold is blanked off underneath, 100 lb. air valve spring)
    2. when the carbs are small enough that WOT vacuum does not fall below about 1.5" Hg
    When doesn't it work?
    The rest of the time.
    Generally, the purpose is just what happened: you looked at it. It's called "posing".
  7. Captain Chaos
    Captain Chaos
    from Missery
    Not exactly panic,
    the monster trucks used to run 3 predators before FI was legal for them,
    but they had 500+ " motors with blowers
    BUT in most cases 1 4bbl is plenty so for our purposes it is for looks . Those blower adapters turn up at swap meets now and again , probaly have to use AFB's since it was designed for predators , holleys would be to big
  8. panic
    panic
    Not exactly?
    Read the post again, paying particular attention to the words.
  9. It has not been abandoned!
  10. twinturbo496
    twinturbo496
    from Cypress
    Front & Rear are 1407's with the choke removed, center a 1410
    All are jetted .110 front & .104 rear
    Accel pump in the middle hole.
    Drilled a 3/8 hole in each air door weight
    They work fine all are second hand. Paid $100 each off craigslist.
    Sure, a pair of QFT dominators would be equal or better in performance, but find a pair of them for $300. (more like $2000)
    WOT AFR drops to 11.0 at the hit from idle, then varies from 11.2-11.7 up to 6800 (data logged with LM-1 wb)
    Plugs look very good, nice thing is that for some reason these don't have surging idle like many of the holley's
  11. couple pictures
  12. dudley32
    dudley32
    nasty...I love it....
  13. gasserjohn
    gasserjohn
    photos
    i street raced a guy from eagle rock socal on york blvd that had a 55chevy sbengine with 3 holleys ......he drove it daily to his job out in ontario .....
    seeing stuff like that as a teenager made me think ............
  14. twinturbo496
    twinturbo496
    from Cypress
    Panic seems a little hostile, but he brings up one good point, too much total venturi cross section will eventually hurt signal strength on a NA engine.
    I suppose booster design will have something to do with just how big you can go, but I don't worry about that with my setup. I believe putting them onto of a positive displacement blower improves signal strength enough that it doesn't really matter, in my case the throttle response is quite good, and I don't have any problems with afr.
    As far as 'posing' I don't go to car shows, just to the track, and most who haven't seen my car run think it is a joke. More than one "expert" has informed me that I would make "way more power" if I got some "good carb's" like Holley dominators... and that AFB's are no good for fast cars.
    I guess since I still have leaf springs in back I don't have a fast car, and don't need good carbs.
  15. ZomBrian
    ZomBrian
    from in IN
    I remember seeing a Quad Quad setup while cruising the bay (e*ay) like three years ago. It was an offy 2x4 with those crossram attachments. I'm sure it was just a dual quad intake with four crossram attachments, sets of two welded to eachother, and then welded to the intake. It looked too out of the ordinary for offy to have done it and it COULDN'T have been able to operate correctly, thus why the guy was selling it?:confused:
