Trippe safety speedlights to replace headlights?
Discussion in 'The Hokey Ass Message Board' started by mndodge, Jul 16, 2013.
  1. mndodge
    mndodge
  2. gasheat
    gasheat
    from Dallas
    Trippe lights are very cool in my opinion. The bubble balancer on top just adds to it. I own one, been looking for a reasonably priced match for years. Yes, trippe lights are very unique. Do you have the large or small trippe....junior or senior?
  3. Fenders
    Fenders
    If you like 'em, run 'em.
  4. tfeverfred
    tfeverfred
    They LOOK okay. How bright are they? Sometimes, you don't know if something's going to work, until you install it.
  5. mndodge
    mndodge
    The ones I have must be around 8" - 8.25" they look to be about a .25" less or close across the lense to the original 29 headlights that I still have on the car, I'm not real familiar with the measurements for the junior or senior sizes, but I saw them and thought they just are a little different then the originals and had kind of a "cool factor" to them I thought.
  6. HOTRODPRIMER
    HOTRODPRIMER
    I say if they work good run them, HRP
  7. mart3406
    mart3406
    from Canada
    I'd be a bit worried about the light
    pattern if you plan on using them
    as headlights. The Trippe "Speed
    Lights" as I recall them, had a fairly
    narrow, more or less "pencil beam".
    Replacing the single-beam bulbs
    with normal halogen or other
    standard, two-beam high/lo headlight
    bulbs won't change the pattern and
    give you an effective and useful low
    beam. Also, putting a dual beam
    bulb in a in a lamp with a lens and
    reflector designed for a set pattern
    with single bean bulb changes the
    focal point and can create some weird
    unwanted light ****ter that can cause
    problems too. You can try it and see
    how it works, but my guess is that if
    you do much night driving, you (and
    probably other, oncoming drivers, too)
    won't be happy with the results. If
    you do it, let us know how it works.
    Mart3406
  8. mndodge
    mndodge
    Thank you for that info about the lights and the pencil beam it throws, as I said I'm a little unfamiliar with them in general.
    My plan was mostly a looks thing with them and planned on more "daylight" driving......but you bring up some valid points cause a gut should never say never!:)
    Thanks mart..
  9. mart3406
    mart3406
    from Canada
    But Trippe "Speed-lights" do look
    so, so cool! I'd say give it a try,
    but be prepared to go to some
    conventional, actual dedicated
    headlights. if it doesn't work out
    too well. One person you might
    want to contact, is a guy named
    Daniel Stern.
    ( www.danielsternlighting.com )
    He can be a bit **** at times, in that
    he's an absolute lighting zealot and
    perfectionist, but he's definitely an
    expert and he know his stuff.
    Mart3406
    <cite></cite><cite>
    </cite>
  10. mndodge
    mndodge
    All the info and the link are a big help!!
    It's nice to have some info from people that their stuff, I saw the lights at a swap meet and just had a great look and thought I would try and give them a try.
  11. BJR
    BJR
    I had a set of Tripp lights on my 1932 Hupmobile years ago. They were more for looks then for light. The reflectors are plated with silver and need to be polished every so often. I believe they only had like a 32 candle power bulb in them. Not to say that you couldn't re bulb them with modern halogen or LED's and make them work.
