Troque Tube Question 54 Belair
Discussion in 'The Hokey Ass Message Board' started by Madsci, Jan 9, 2013.
  1. Madsci
    Madsci
    from Canada
    I know this has been throw around a thousand times, however, on a 54 Chevy to pull the engine and transmission, can you just loosen the collar on the torque tube while leaving the pivot hosuing attached to the transmission and pull the engine and trans ? or do you have to lossen the collar and remove the bolts and slide the pivot housing back and split the u-joint connection???
  2. 40FordGuy
    40FordGuy
    Loosen the collar,..Slide the slide the housing back, and take the u-joint apart.
    4TTRUK
  3. 5-4Belair
    5-4Belair
    Just pull the engine and trans as a unit and the tube will come out of the pivot housing.
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    You will 99% sure when you go to put it back together you will end up taking it apart anyway.
  5. Madsci
    Madsci
    from Canada
    No worries its not going back in.....swapping motor,trans and differential...
  6. 5-4Belair
    5-4Belair
    I dropped the rear, springs and all, and pulled it right out of the trans.
  7. Madsci
    Madsci
    from Canada
    Did that today! Thanks for the info..........
