1952-59 Ford Trouble changing rear tires on a 1952-56 ?
Discussion in 'Off Topic Hot Rods & Customs' started by JeffB2, Aug 4, 2016.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
  2. 56longroof
    56longroof
    Stock or lowered? Is there a difference between a 55 and 56. Just wondering if this would apply to a 56.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Lowered would call for measuring the collapsed and extended length to see if it could be used.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Jeff,you should be able to edit the ***le with the ~ Thread Tools ~ on the right side of the page. HRP
  5. Texas57
    Texas57
    The '57 guys are doing that also....probably a different shock though. We use a Monroe shock for a '55 Ford...... As Jeff mentioned, it lets the axel drop another few inches eliminating the need to undo the shocks to get the necessary clearance. I have them on mine, and I can research the number if anyone needs it.
  6. bobss396
    bobss396
    My '59 barely lets me change the bigger 15" tires jacking it at the same point. But great tip on the alternate shocks.
  7. rick55
    rick55
    My 55 is stock height on the rear and the shocks I have wont allow me to remove the tyres with loosening the shocks. I'm just about to instal some new replacements. An absolute PITA.
  8. Jimmy2car
    Jimmy2car
    from No. Cal
    My 56 Ford is not lowered, so could I also use the Gabriel shock #82125?
    Also, my friend has a 52 Mercury with 3" lowering blocks. Does anyone have a shock number that will work for him?
    Thanks
    Jim
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    You can use the 82125.
  10. Jimmy2car
    Jimmy2car
    from No. Cal
    Thanks so much, Jeff.
    The timing for this is perfect, as the old shocks are Old Monroe Air Shocks that really don't work at all.
    Wonder if anyone has a number/brand for the 52 Merc I mentioned, that is lowered?
  11. Jimmy2car
    Jimmy2car
    from No. Cal
    As a bit of info, the Gabriel shock 82125 is also a NAPA # 94049
  12. jerry martin
    jerry martin
    Is this shock shorter than the standard shock? And what is the number for the front shock and how much shorter is it?
  13. Jimmy2car
    Jimmy2car
    from No. Cal
    Jerry
    I don't have a number for a front shock.
    I think I used the ones recommended by Jeff, when using the Aerostar springs.
    The rears, I think, are longer than stock, but not sure
    Jim
