Technical trouble shoot sbc lifter
Discussion in 'The Hokey Ass Message Board' started by c/h, Jan 8, 2017.
  1. That's another good point, maybe 1 is oiling correct and the other 7 or 15 have issues.
    That would make a bunch of racket too.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    We don't need a video with audio. Listen to the words written above. Your going to have to tear into things like or not to find out things. I'd rather pull an intake first rather than pull a trans. Tell you what. Instead of a video can you tell us how much preload you've put on that lifter trying to quit it.
  3. You can't load a video here- Post them to youtube then give us a link
  4. I was thinking a bit about what I brought up. What do you guys think as to testing for cracked flex plate. Remove all 3 converter bolts and push converter into the pump till it bottoms. Using a pinch bar reach up between pan and flex plate and put pressure on the plate. Turn motor a bit and check again till you make a full rotation. Think that might create the sound if it does in fact have a crack in it?
    The Wizzard
    tb33anda3rd likes this.
  5. seb fontana
    seb fontana
    from ct
    Could be as simple as the torque converter bolts being loose..
  6. I've found loose converter bolts to only clatter till put in gear. Once pump load is on the thrust keeps it from ratteling back and forth in the holes.
    The Wizzard
  7. c/h
    c/h
    from iowa
    bolts tight
    weight tight
    il pull inspection cover see if there is anything to report only 4 bolts
  8. Jerrybigbird
    Jerrybigbird
    from Montana
    Could be loose bellhousing bolt(s) also.
  9. c/h
    c/h
    from iowa
    11 degrees out
    flywheel solid no issue. checked mounts bell housing pretty much everything external
    start it no sounds in park put it in gear hold the brake bring it up to 2500-3000 here comes the noise.
    would piston slap wrist pin make noise at start and in park or neutral?
  10. If the flex plate is cracked they crack like this.
    You can not see it when Trans is installed.
    There are some YouTube vids on diagnosing the sounds
    Look at them
  11. bobss396
    bobss396
    This is a 2 person job, have one person hold the car in gear and get the noise going. The other listens at various places with a wooden dowel held to the valve cover, bellhousing, maybe the fuel pump. Hold the other end of the dowel close to your ear.
  12.
    hotrodharry2 likes this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Off this topic but I have to ask. I've seen others post up a quote but not write anything like here. Is this a new way of saying X2 ?
    Flathead Dave likes this.
  14. Flathead Dave
    Flathead Dave
    from So. Cal.
    I've wondered about that.
  15. Blues4U
    Blues4U
    from So Cal
    He did write something, you have to click on it to expand it. It happens like that because he wrote his reply inside the quote tags, so his comments became part of the quote.
    ClayMart and Johnny Gee like this.
  16. hotrodharry2
    hotrodharry2
    from Michigan
    Experience has taught me about the flex plate problem. I've never been able to diagnose it before pulling the engine or the trans. Of course I do most of my work by myself, I don't have the luxury of someone close to help. I have to agree with all the others, it's time for a tear down one way or the other. Good Luck!
  17. What kind of torque converter you got to go 3000 rpm with the brakes on? Maybe it your brakes creeping...... no! JW
  18. c/h
    c/h
    from iowa
    well its been interesting morning
    drove it noise came back from about 25 miles out called my buddy had him have a trailer ready cause I dint know if it was going to go.when I was on the phone with me nothing all the noise went away runs like new tried to get it to clatter like before and I cant.
    now going with maybe a oil p***age blocked and just came out of it I don't know.all I can say it runs like new the sound is gone.I don't have a explanation I sorry wished I did.
    thanks for all the help from everyone and there input
    something comes of it il be back on
    thank you
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I'm happy that your happy. And yes, do get back with us. Lifter's, if that's it can be tricky little devils and hide for a while and bam !, what back in your face. Did you read the post here about maybe the fuel pump ? Just another thing to keep in mind down the road.
  20. Fuel pump and lifters are not affected by engine load.
    I have a lifter in my 301 Chev that suddenly sounded like a big end. restarted it and it slowly reduced to an annoying tap, I am hoping it will also go away. JW
  21. If you actually believe a motor issue can cure itself, Now would be a real Good time to invest in Triple AAA. The time you actually need your Pal with the trailer he's going to be out of town.
    The Wizzard
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I've got a tappet like that in the car shown in my avatar. It isn't going away. I've been shut it up just like you for over 3 years. Lifters these days are not make equal and the ones I have a notorious for that. But I'm just as stubborn as that lifter. I'll let him show me where he is in a crowd before I go looking for him.
    26 T Ford RPU likes this.
  23. I've never seen a motor issue permanently self correct. It will be back
  24. I smell Popcorn;):rolleyes: JW
  25. c/h
    c/h
    from iowa
    drove that ****er all day no noise.
    I wont be surpise if it come back but where did it go.im guessing wrist pin put its self back spot .
    il lined my self up with a new engine when it comes back hope not for a while I need to get caught up and it flipping cold here to change a engine in a shop with out heat
  26. Pist-n-Broke likes this.
  27. sunbeam
    sunbeam
    A pru
    If a press fit wrist pin changed it's position you've got big problems.
  28. c/h
    c/h
    from iowa
    went and changed my engine for a new one.
    problem: piston skirt broke bottom of the pan.still ran like new .I decide get it taken care now.
    26 T Ford RPU and Johnny Gee like this.
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Thanks for the up date.
