Technical trouble shoot sbc lifter
Discussion in 'The Hokey Ass Message Board' started by c/h, Jan 8, 2017.
  1. 48fordnut
    48fordnut
    The dowel is the best advice given yet. I use a broom stick. Finds all kind of noises.
  2. 19Eddy30
    19Eddy30
    from VA
    Automotive Stethoscope is a better Tool to use , I used to track down a bad valve guild , install a Vac cap at the end ,cut tip off for better results , you can stick between oil pan & flex plate while running if you think it's cracked, another tool bore scope to check for crack with out pulling trans.
  3. Blues4U
    Blues4U
    from So Cal
    A length of heater hose works well to isolate noises and identify where they are coming from, easier to use than a solid dowel or broom stick IMO.
  4. 48fordnut
    48fordnut
    What ever is at hand and works for you is the correct tool. :)
    26 T Ford RPU likes this.
  5. seb fontana
    seb fontana
    from ct
    Or read post #58..
    Johnny Gee likes this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    "No body told me to hold the dowel to my eye"
  7. The update is great, thanks
    But what about the loose rocker and excessive oil?
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ If broken skirt was #1 piston it may have chased the exhaust valve while the valves where floating for some odd reason.
  9. Well I'll just add this to the pile -
    Loose rockers is the result of broken piston skirt. Or did the rocker break the skirt ? Hummmm
    v8deuce likes this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Aunt Mollie is fine. [​IMG]
    v8deuce and 31Vicky with a hemi like this.
  11. v8deuce
    v8deuce
    Oh my god I must b getting old!!! I just figured this out damn funny!
