Technical Trouble shooting
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 18, 2025.
  1. Jalopy Joker
    Jalopy Joker
    good that there are some guys here that are "well grounded" in troubleshooting
  2. HOTRODPRIMER
    HOTRODPRIMER
    You Bet! HRP
    Stogy, osage orange and Sharpone like this.
  3. Sharpone
    Sharpone
    Dielectric grease is non conductive IMO I wouldn’t use at the electrical connection itself between the metal parts that conduct. It can be used on the connection after everything is tightened. A coating of regular grease on the outside will work just as well.
    Dan
  4. RICH B
    RICH B
    Grounds can be interesting; had one of our suppliers go from wet to powder paint. Suddenly had ground problems, they bolted the ground cables and wires down to the now powder coat finish; easy fix, grind the power coat off, good grounds again. Supplier paid warranty and decided the fix was a stud welded to the frame to connect the grounds; guess what, a powder coated stud doesn't make a good ground either.
  5. GlassThamesDoug
    GlassThamesDoug
    Never have enough grounds.
    Sharpone likes this.
  6. Bentrodder
    Bentrodder
    from Cotati
    I know your issue was ground but a different "run great than no click" issue I had was a loose connection on the neutral safety switch. Was still attached but could wiggle it and make a connection.
    Sharpone and osage orange like this.
  7. Loose starter, bad grounds, you need 3 engine to frame engine to firewall, engine to starter. Too many is always good when it comes to grounds.
    Sharpone and 26 T Ford RPU like this.
  8. LOST ANGEL
    LOST ANGEL
  9. HRBOB34
    HRBOB34
    If you have a kill switch?
    Its bad! I have had that happen a few times!
