1952-59 Ford Trouble starting 239
Discussion in 'Off Topic Hot Rods & Customs' started by voodookustoms, Dec 1, 2014.
  1. voodookustoms
    voodookustoms
    Now that I've got my car drivable (electrical and front end rebuilt) it has trouble starting after it has been on and running for a few minutes. It starts cold easy. I have to crank on it and give it a pedal stroke or two to get it going again. But once it cools off again, it starts right back up. I have a 600 edelbrock carb on it.
    Any one have any ideas? Or places to start? Thanks.
  2. voodookustoms
    voodookustoms
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Manual choke or electric choke on the Edelbrock 600? Also Edelbrock (aka Carter AFB) Carbs are very heat sensitive,do you have a heat insulator spacer between it and the manifold?
    voodookustoms likes this.
  4. voodookustoms
    voodookustoms
    Hey Jeff. It's a manual choke. And I have heard about them being heat sensitive. There is an aluminum spacer between the intake and the carb, but I don't know if it's an insulator or just an adapter plate.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. voodookustoms
    voodookustoms
    Awesome. Thanks Jeff. I'll give that a try.
  7. voodookustoms
    voodookustoms
    I got the insulator gasket in the link. I looked for other 4 bore gaskets, but they don't sell them (Except in a 2 pack for dual quads). Do you see a problem running an open plenum type gasket on an intake with 4 seperate bores?
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    I don't think it would be an issue as long as it is sealed all around the base,I have done it without a problem in the past.
  9. voodookustoms
    voodookustoms
  10. voodookustoms
    voodookustoms
    I put the insulator gasket on and leaned the carb out a lot. Followed directions from edelbrock's youtube video and she runs like a champ now. Starts up easily after sitting hot for a while and it idles much smoother now too. Oh, I also cleaned all the gunk out of the fuel bowls and jets when it was off. Think that helped with the rough idle. Anyways, thanks for your help Jeff.
