Trouble with a Gennie Shifter
Discussion in 'The Hokey Ass Message Board' started by jscoma47, Nov 24, 2008.
  1. jscoma47
    jscoma47
    Now I have gone through all the pages that came up from searching and it seems that no one else has had this problem.
    I bought my shifter for a th400 and the brackets dont fit,they sent me another set of brackets that are the same,needless to say, they dont fit.
    I am waiting to hear from Race over there.
    MY question is...is there anybody out there that has any fitment issues with this particular transmission?the brackets are short, meaning they fit real tight and there is about 7/16 - 1/2" of space between the shifter and brackets,the supplied bolts are way too short.
    I know there could be casting differences in ******s. I even tried to grind the first set of brackets down to get em closer.
    Please let me know if any of you guys have run into any similar problems,
    I followed there instruction to a T and now I have a nice hole in the floor of my daily driver......its getting cold in here...
    Thanks in advance for any help
  2. iamspencer
    iamspencer
    I think Alex Gambino sells those, mybe he can help, he's on the JJ
  3. jscoma47
    jscoma47
    I bought the shifter from Alex. He was great to deal with.
    I just reinstalled the new brackets and took measurements, There is a 5/8" space between the shifter and brackets. The brackets are tight to the body of the trans.
  4. Duration
    Duration
    from Wayne, MI
  5. Jerry27Tub
    Jerry27Tub
    I had the same problem with a Gennie Shifter for a Ford AOD. The brackets just would not line up. I ended up cutting down the side brackets and making new tabs for the ****** to get it mounted solid. Not a big deal, but when you pay the bucks for something that's supposed to bolt right on, it is frustrating.
  6. stillkruzn
    stillkruzn
    from Conway, AR
    I have the Gennie Shift for Ford AOD and the brackets fit just fine... I have the rear mount on mine... make sure you are installing it in the correct spot, they have side/top/rear mount brackets...
  7. oldrelics
    oldrelics
    from Calgary
    Real tight but should go, I thought mine were wrong too, till I had to file off some rough trans casting flash then JUST went on. I like nice tight stuff!
  8. thewildturkey46
    thewildturkey46
    from Rice, MN
    I used a Gennie on my T400 with no problems, besure to get ahold of Race, he is always very helpful on everything.
  9. 325w
    325w
    GM had a 375 trans that looked and walked like a 400. Could it be you got one of those. Find a picture of the oil pans and you can see the difference. Just a thought.
  10. fab32
    fab32
    Not unless you want a whole new set of problems. :mad:
    Frank
  11. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    call me please would like to help since i sold it
    thanxs
    alex
  12. jscoma47
    jscoma47
    Just a quick update...
    The problem has been solved... Thanks to Race and Janette over at Gennie and Alex from Gambinos.
    There was a missing hole on the first bracket set, the second set had it but I didn't see it.
    These are all great people to deal with and the current special Alex is running can not be beat.As a matter of fact I am ordering one for my other car.
    This has to be one of the nicest shifters on the market.
    Thanks to all that helped.
    Jesse
  13. fab32
    fab32
    Glad you got the problem solved. The Gennie that's in my '32 has been giving good service for almost 10 years over 40,000 miles and hasn't been readjusted or the tension changed since I installed it. The Lokar in my wife's '37 is the biggest POS I've ever had the misfortune to encounter.
    Frank
  14. KIRK!
    KIRK!
    Call Gennie, they are about as cool as a company gets. If you get stuck, ask for Race - tell him I sent you. He'll help you out - he knows EVERYTHING about EVERYTHING they make.
  15. Martin_F
    Martin_F
    Is there a difference between Chevy TH400 and Olds Th400???
    Or would the brackets of the Gennie fit both??
    Thx
  16. phat rat
    phat rat
    I've got over 50,000 mi on my Lokar without any problem
