Troubleshooting Timing Advance
Discussion in 'The Hokey Ass Message Board' started by seacat95, Mar 12, 2012.
  1. seacat95
    seacat95
    I am thinking it's time for a new distributor, but wanted to double check my thinking.
    What I have is 292 Chevy (65) just got done putting on a Offy 4 bbl intake and Edelbrock 500 and loving that, I have gotten rid of my intake leaks and now trying to get things dialed in perfect. I read through Leo Santucci's book last night. Here are the numbers I have now.
    Vacuum at idle hooked to manifold 18
    Vacuum at 3000 rpm 15
    Base timing w/ no vacuum 11 deg.
    Base timing w/ vacuum 30 deg. So right here I am almost at peak timing for the motor with Leo saying 32-38 at 3000 rpm.
    3000 rpm w/ vacuum 60 deg
    3000 rpm w/ ported vacuum 50 deg.
    I am thinking the distributor may be worn, or vacuum canister. It's HEI and was on the truck when I got it so I have no idea what it was pulled from or how old it is. I have been eyeing a few on ebay, but may also play the ultra safe route and get a new one from the parts store.
    http://www.ebay.com/itm/290616883673?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_500wt_1054
    http://www.ebay.com/itm/350518869050?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_6093wt_1270
  2. seacat95
    seacat95
    What lead me to check all of this is the fact she idles great, slow acceleration no problems at all, ANY kind of quick acceleration (with a load) and it starts pinging bad. No other symptoms and will run good at speed. I do have a fuel pressure regulator and per Edelbrock set at 5.5, and new fuel filter with the carb replacement.
  3. hotroddon
    hotroddon
    You are are missing the more important reading. Check the timing without the vacuum hooked up (and the port on the carb plugged). It should be around 32° all in by around 3000 rpm. If it is more than that, then you need to tweak the mechanical advance to limit it.
    As for the vacuum, 50+° is not uncommon, remember that as soon as you put your foot in it the vac will drop and the timing will back off. Also many aftermarket vac canisters are adjustable so you can back off the amount of vac as well.
  4. seacat95
    seacat95
  5. seacat95
    seacat95
    Ok at 3000 rpm with vacuum unhooked from the distributor and capped I am sitting at 28 deg. So I can advance my mechanical more to get that dialed in closer to 30-38. Maybe continuing to bump it up will get ride of the pinging, but I thought the pinging was coming from too much advance?
  6. seacat95
    seacat95
    I bumped the base mechanical time up to 18˚, now giving me total timing at 3000 rpm, 32˚. She's not all in until 4000 rpm. I'm thinking I'll be getting a weight kit with stiffer springs to get it all in at 3000.
  7. seacat95
    seacat95
    Just went out for test drive, definitely heading in the right direction with the current settings. A normal driver would never hear it ping, getting into has it pinging over 2500.
  8. ottoman
    ottoman
    from Wisconsin
    Maybe I am misunderstanding what your saying. First softer springs will get it all in by 3000 if its all in by 4000 now, not heavier. Second you have to know how much mechanical advance is in the dist now... if its 22 total mechanical (example) then you set base at 10 degrees at idle and work with the springs and weights to get it all in (32) by 3000.
    Third yes many times we restrict the vacuum advance so there isnt too much. There is usually a slot the rod hits to limit the total movement of the vac advance. I have brazed or welded up the slot and ground it out untill I had what I wanted also many GM vac advances had the degrees of advance stamped on them so some digging in the yards or parts stores might help you find what your looking for.
  9. Dooley
    Dooley
    from Buffalo NY
  10. brokenspoke
    brokenspoke
    use a va*** canister for a large truck
  11. seacat95
    seacat95
    Went to tour the Blue Bell Creamery today so hopefully tomorrow I will have time to pull the cap and look at the numbers. I have note messed around with weights and springs before, reading up on it. I appreciate the help and tips.
  12. seacat95
    seacat95
    Like 2ton, with 292? I am thinking grain truck.
