Hot Rods Truck 5 speed
Discussion in 'The Hokey Ass Message Board' started by Stickbilly, Jan 12, 2015.
  1. Stickbilly
    Stickbilly
    from Liberty,KS
    I have a 95 1/2 ton Chevy truck 5 speed and I wondered if anyone has ever tried putting one of this in a car? I'm thinking of putting it in a station wagon.
  2. mcmopar
    mcmopar
    from Strum, wi
    I an putting a 95 Dakota 5spd in my 1937 Dodge truck. It is a AX 15 the same one that is in a Jeep. I have a feeling I will only get a year out of it. I believe it should hold up well. What are you doing for a speedometer?
  3. squirrel
    Trucks generally have a taller frame than cars. Do some measuring, see if it looks like it would fit. As far as the shifter location and length, it might be appropriate for a 1930s car, but not a 1950s car....cars got lower as time went by, on the later ones you sit less upright. Trucks didn't do that so much.
    lothiandon1940 likes this.
  4. need louvers ?
    need louvers ?
    My very first thought would be, "what are the gear ratios" ? most trucks have a fairly worthless first gear for damn near anything but pulling stumps.
  5. junk yard kid
    junk yard kid
    Is that the NV3500? Ive got one here at the house. I know it'll fit in a 53 ford with minimal cutting to the floor. Ive seen pictures on here of a couple model A's using them.
  6. Jet96
    Jet96
    from WY
    Some half tons had alum. case and had ratios very similar to T5. Just a little bigger, couldn't recall the model off the top of my head.
  7. treb11
    treb11
    Its what I put in my 40 PU. Fits nicly. Same mounting point as TH400. Shifter comes out in the right place.
  8. 35desoto
    35desoto
    Don't put the AX-15 down - they have got some strength - they were used in many medium torque applications from being behind diesel engines through to v8 mopar engines. First gear is a bit low but that allows you to use a better diff ratio for great cruising esp in 5th gear
  9. texkbc
    texkbc
  10. pdunn10
    pdunn10
    That is a nv3500.
    good first and a big overdrive.
    I would check the shifter location for a non truck application
