truck drop axle in model T pix anyone?
Discussion in 'The Hokey Ass Message Board' started by Jbirds51, Oct 3, 2011.
  1. Jbirds51
    Jbirds51
    from Sac ca
    I have a 46 ford truck front end that id like to use on my 27 sedan..Does anyone have any pictures I can check out for inspiration?I have seen it done I just can find any photos of one done.I have searched here and elsewhere to no avail.help?! haha.Thanks.
  2. chrisntx
    chrisntx
    from Texas .
    The term you are thinking of is 'DROPPED axle'
  3. Jbirds51
    Jbirds51
    from Sac ca
    right dropped...anyhow a little more description as to specifics..Id like to transverse the spring on an originally parallel leaf axle.I saw one at a car showabout a decade ago.The guy made a plate that bolted to the 4 shackle bolt holes and used split bones from it..I was hoping to see more pics of something like that.
  4. Mr48chev
    There is a guy/family in the Cl Elum Wa area that has/have a couple of wicked T buckets with that setup. I've got photos somewhere in the photo stash if i can find them. On those two you didn't notice that a parallel leaf axle had been used at first.
  5. As far as I know there is no shortage of early Ford I beam axles, spindles, brakes, springs, perch bolts, wishbones, misc parts, or the information on how to install them; so why would someone want to go to the trouble of cobbling up a pick-up axle to use in their place.
  6. Hackerbilt
    Hackerbilt
    Could be lots of reasons why...doesn't really matter!
    Something you might need to watch is that the truck axle doesn't have the "smile" (dip) in the middle so it might be a little tight on clearance for the U bolts of the transverse spring.
    Make sure you have a strong yet goodlooking connection between your axle and control arms and spring mounts.
    The hard part of this is making it look nice. Strong is easy.
  7. designs that work
    designs that work
    There have been three threads in the last month about pick up axles. Yes they can be cut and welded safely. Yes the bolt pattern is early 5 x 51/2. No KH bent spokes will not fit without a spacer.Yes you can mount a transverse spring if you know what you are doing and a good welder.Look at my woodie album the race car has a 1056 Ford PU axle converted to transverse spring.
