Truck rear
Discussion in 'The Hokey Ass Message Board' started by darkk, Oct 27, 2013.
  1. darkk
    darkk
    Another of my 46 ford pickup questions. What is the *wheel mating surface* wms to wms of the 46 pickup ..what 9" ford rear would fit close to the same width?
  2. HOTRODPRIMER
    HOTRODPRIMER
    Deuce Roadster posted that the 46 Ford truck is 60" measured from wheel mounting flange to wheel mounting flange.
    As I recall he used a explorer rear axle. HRP
  3. darkk
    darkk
  4. 55 dude
    55 dude
    If a 46 rear is the same as a 48 then a 1/2 ton trucks rear up to 72 will be correct width.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Actually a 1957 to 1972 F100 is 61 1/4" which is only slightly wider. HRP
  6. 117harv
    117harv
    Here is a pic with dimentions of all years, the later bnanjos are 61" not 60. Many 9" rears measure 61 1/4" so finding one shouldn't be a problem. Enlarge the pic, than double click it to enlarge more.
  7. pasadenahotrod
    pasadenahotrod
    from Texas
    42-47 Pickup open drive rears are the same width as the 42-48 closed drive P***enger rears and use the same axles, brakes, etc.
