truck wind noise
Discussion in 'The Hokey Ass Message Board' started by chevyv8t, Jan 27, 2011.
  1. chevyv8t
    chevyv8t
    I get to much wind noise from around the door windows on my 51 chevy 3100 has anyone got a fix
  2. Kustom Chief
    Kustom Chief
    If it has good door rubber and window seals nad door alignment, Go with a louder radio, or ear plugs.
  3. handyandy289
    handyandy289
    from Georgia
    It is hard to not break wind in a chevy. LOL
  4. 302GMC
    302GMC
    from Idaho
    They're just noisy going faster than 50 or so ... open both wing windows an inch helps a little. Window channel & new wing window rubber always help.
    Beautiful color on your truck !
  5. kustom beale
    kustom beale
    from ladner b.c
    interior windlace?
  6. chevyv8t
    chevyv8t
    maple pearl volvo v60 colour
  7. rusty1
    rusty1
    ...drive under 50....sorry, couldn't help it.
  8. racinman
    racinman
    and you also have the wind cutting visor on there... I like it !!
  9. bobss396
    bobss396
    How flush are the doors to the body? Maybe a tall order on an old truck, but worth a look.
    Bob
  10. Make sure all your vents are sealed around heater case creating a VAC
  11. spot
    spot
    from usa
    I had a similar problem on an OT truck I built a few years ago. I added another bulb weather strip around the doors leading edge just inside the lip to seal the door so no air could get between the door and the jamb. Not as quiet as a new car but it made it so a conversation in the truck at hiway speeds could be had without yelling.
  12. chevyv8t
    chevyv8t
    thanks eveyone who answered found out today if I pull the doors from the inside while driving it gets a lot better so its got to be the door fit
  13. Petejoe
    Petejoe
    from Zoar, Ohio
    Nice truck. Sets great and clean! Reminds me of my old one.
    I see you kept the wings. Did you install all new rubber?
  14. Mr48chev
    I've fought that battle for the past 38 years and haven't won yet. Fresh weatherstripping and windlacing in good shape helps along with having the door latches adjusted as you discovered. Also make sure that all of the weather related items around the door gl*** is in top shape.
  15. larry k
    larry k
    the problem you have is wind noise but not a wind leak, it's the same as blowing across a sode bottle hole, the wind moves across the door gaps and makes this noise, that 51 was not built to run an interstate at 75 mph like it does now, all old trucks have this problem to some degree, plus that mirror and those visor braces ain't gona help much,, "ya" hip ?:cool:
  16. Kripfink
    Kripfink
    All I can add to this
    is get yourself some hollow door rubbers. I recently replaced my solid rubbers with a hollow kind and now have perfect door fit that I could never achieved before.
    Best of luck.
    Paul
  17. Keep it in the garage, no wind noise.
  18. the-rodster
    the-rodster
    Put a dollar bill, in your case a euro maybe, around the opening and close the door on it. Check to see how tight the seal is by pulling on the dollar, you may need to bend the window frame in toward the cab to get a better seal at the top.
    Helped mine a lot.
    Rich
