true or false?
Discussion in 'The Hokey Ass Message Board' started by nickk, Aug 10, 2011.
  1. nickk
    nickk
    i was once told that you cant use mechanical drums with juice brakes, im pretty much wondering if you can use the 36 through 38 wide 5 drums for juice brakes, ive been told a few different thing, just hoping someone may help clear this up
  2. 117harv
    117harv
    Yes you can. The 36 drums won't work with the later juice backing plates as they are a one year only drum with a different offset. The 37-39 will work fine.
  3. nickk
    nickk
    thanksss! and im guessing thats the same for the rear?
  4. Richard (EV8G)
    Richard (EV8G)
    The 1936 fronts CAN be used with 39-40 "deep" Lincoln-Bendix brakes on the original
    1936 spindles, as the deep Lincolns have the same small bolt pattern as the spindles. A special kingpin/bearing kit must also be used in order to eliminate the "socket" on the original kingpin tops (which support the car!!! so cannot just cut them off!!!). The
    same applies to 1935 front hubs/drums. The tops of the spindles must be modified (ground flat) to clear the brake plate...
    1935 and 1936 rear hubs have the same offset as 37+ and therefore CAN be used with
    rear hydraulic brakes (39-42 or 46-48 Ford/Merc or 39-48 Lincoln)
  5. 117harv
    117harv
    Thanks Rich for the great info.
  6. Bruce Lancaster
    Bruce Lancaster
    And...'37-38 drums are not only usable, they are in fact the SAME drums used in 1939 for the hydraulics.
  7. nickk
    nickk
    dang, i do apprieate the information, ive been told so many different things but byfar that seems the much legit
