Technical True Survivor 32 5 window 50 yrs off the road !!
Discussion in 'Traditional Hot Rods' started by Limey Steve, Nov 11, 2009.
  1. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    This absolutely killer 5 window was built by Doug"s (the current owner )Dad back when you could buy a 32 coupe for $25 (his dad wouldn't let him buy the deuce roadster he found as it was deemed too dangerous !! ) The coupe was hopped up with a Flat head motor , dropped axle, reverse eyed spring (done by a local blacksmith ) & 46 juice brakes. It was painted this killer blue with the white pleated interior with blue piping. Doug's dad hot rodded it around & then stuck it in a garage, removed & primered the front fenders , took out the fllathead , filled the rear panel after removing the Chevy tail lights & then sat it up on blocks for 40 years .
    Doug got the car 10 years ago& put it back together , had a flathead built & then brought up his family & stored the coupe for almost another 10 years .When he got around to starting the engine there were some serious issues with the build , Doug tried to bandaid the problems but when water started pouring out of the tail pipe on the drivers side he threw in the towel.
    It was then that I got a call from Doug to ask if I'd take on the project of getting his Dad's old coupe back up & running. I was honored to be a small part in the life of this fantastic coupe. It was love at 1st sight when the car arrived ( we do have the hood with the pinstriped louvers to go on once I've got the heads finally torqued down )
    We pulled out the motor, found the pistons were above the deck & hitting the New Navarro heads (even with .100 copper gaskets fitted ) at tdc.It was a stroked Merc crank with floating bearings .
    Parts were taken to Taylor Engines, the crank magged Bad (3 cracked Journals !!! ), the 59 A block magged good as did the rods, but when pressure tested the water was coming out of # 5 as they had drilled & put a hole in the exhaust port (putting in a heli coil ) I made a plug for the hole & fixed the leak, we got a new stroker kit from Scat & built the motor using an Isky cam. The Heads were from the original engine Doug's Dad built. The rest is as found with some subtle stuff Doug did to make it drivable today. If you want to see an example of a 50's Hot Rod check this one out, btw no patches anywhere on the body . The Tires are the originals too!!Man I love it.
    [​IMG][​IMG]
  2. cruzr
    cruzr
    Ive seen this car at Limeworks, and its the real deal!! Whats not to like,wish it was in my stable!
  3. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
  4. McFly
    McFly
    oh so jealous...beautiful!
  5. SinisterCustom
    SinisterCustom
    Wowie.....that's a '32 I wouldn't mind havin'.....
    Just bitchin'!
  6. scootermcrad
    scootermcrad
    Pictures do NOT do this car justice!
  7. Standard32
    Standard32
    from LA
    really sharp car... and cool that it stayed in the family all those years...
  8. Now that is cool! It probably had the wrong pistons from the get-go . . . caused the pistons to hit the heads. Glad to see this car back on the road!
    Dale
  9. VinnieCap
    VinnieCap
    Who wouldn't love it. Great car!
  10. hershambob
    hershambob
    wow,thats nice.my dad had viva vans.
    besure to check for traffic wardens steve as they got me in that alley back in june!!!
  11. Thanks for the pics Steve!
  12. slammed
    slammed
    Man.............it's so neat that it hurt's! Almost like love really.
  13. Wow Steve that sure brings back memories of my ol blue Coupe. Thanks for sharing the pics........Cheer`s Bri
  14. 327-365hp
    327-365hp
    from Mass
    WOW, what's not to like about that car, and it's a great story to boot! Glad it's running again so everyone can enjoy it. Good job guys!
  15. dullchrome
    dullchrome
    from SoCal
    I have seen that car at the shop also. That little ride is about as cool as it gets ! ! !
  16. hotrd32
    hotrd32
    from WA
    WOW....just get it running and drive it....what else is there to say......beautiful!
  17. Dave K
    Dave K
    Wow
    Love it!!!!!!!!
  18. mj40's
    mj40's
    That one brings back all the memories. My first ride in a hotrod was in a 5 window the same color in the 60's. We went thru the 1/4 mile at over 100 mph and I knew I had to have one. The only difference was it had a 327 with a 4 speed.
  19. citcapp
    citcapp
    from Bothell WA
    Time tested hotrod looks as current today as when it was built. Doesn't get any better then this
  20. fab32
    fab32
    That's the kind of car every hot rodder hopes to come across at least once in his lifetime. I walk past mine every time I go in the shop..
    Frank
    kidcampbell71 likes this.
  21. HomemadeHardtop57
    HomemadeHardtop57
    they are still out there...love the old sticker on the window
  22. aldixie
    aldixie
  23. Malcolm
    Malcolm
    from Nebraska
    Damn that is cool! ...And a great story, too!
    Thanks for sharing it with us, Steve.
    Malcolm
  24. Ryan
    Ryan
    ADMINISTRATOR
    That car looks Texan. I love it.
  25. Buz
    Buz
    Wow, what a time capsule.
  26. brady1929
    brady1929
  27. RAY With
    RAY With
    Good story and great car . Thanks for the post
  28. That's fantastic...what a time capsule...I love the not-too-wide whitewalls...
  29. Sphynx
    Sphynx
    from Central Fl
    Its perfect wouldnt change nothing but the name on the title .
  30. MR. FORD
    MR. FORD
    from Austin, TX
    Unbelievable.........
