truly the dumbest question you've read in a while!
Discussion in 'The Hokey Ass Message Board' started by Devin, Jun 11, 2005.
  1. Devin
    Devin
    from Napa, CA
    Here she rips:
    I've just set up my spring behind axle suspension on my A. I like the clean looks of having no shock absorbers. I don't want an unsafe car however. How many of you guys (if any) roll shockless? Am I a danger to myself and others?
  2. jalopy43
    jalopy43
    I went shockless on my A sedan for about 2 weeks. nothing real bad, but a certian speeds it got a harmonic, and danced and jiggled enough to drive me nuts. I built aome shock mounts out of square tube, welded to the frame, and used some used '50 ford tube shocks,with mounts welded to the bones. Sparky
  3. HOTRODPRIMER
    HOTRODPRIMER
    I'm im South Carolina,,,I don't think I have to worry about you bouncin' in my lane! :D Ha,ha,,,
    Is it the front or rear,,,you didn't say,,,,,if its on the front why not go with friction shocks,,,,,they don't distract from the look and are to your advantage to keep the car from bouncin' like a basketball when you come to a hard stop! :eek:
    BTW,,,it ain't the dumbest lately,,,,,,weldin' the axle to the frame was! :rolleyes: HRP
  4. Derek Mitchell
    Derek Mitchell
    Yeah, its dangerous if you hit a good woopdidoo section.
    Shocks don't look that bad, you could always go the friction shock way.
    I'm planning on doing the same style front on my car and running friction shocks, but if that don't work out , I'm gonna put shocks on her.
    I like to be in control of my car.
  5. DrJ
    DrJ
    Be fine as long as the car won't do over 35-40mph with a good tailwind. :rolleyes: :cool:
  6. Corn Fed
    Corn Fed
    Don't under any cir***stances go shockless. I took my "A" out for it's maiden voyage without front shocks. Within the 1st 4 miles of highway speeds one wheel hit a pot-hole starting the whole front end seriously bouncing back and forth. I'm amazed I got it stopped in one piece. Bent my split bones mounts and tie rod. Learn fom my mistake. C.F.
  7. Not recommended at all.
    Can you put shocks in front of the axle?
  8. Blacktop Graffiti
    Blacktop Graffiti
    "BTW,,,it ain't the dumbest lately,,,,,,weldin' the axle to the frame was!"
    I never said I was smart.
  9. It's NOT the dumbest question if you're ASKING it! You obviously had some concerns and weren't afraid of what people might think.Bravo for asking.
  10. InDaShop
    InDaShop
    from Houston
    Right on. There is a huge difference in being stupid, vs. knowing your stupid.
  11. 30roadster
    30roadster
    here is a good picture of a front end setup - not quite like you described ( spring on top of axle )...but the friction shocks are fairly hidden. If you painted them they would disappear.
  12. fatabone
    fatabone
    Do a search and check out front ends to find the shocks you'd like best. I like the looks of the MG and friction shocks nice small package. I have MG shocks on the front of the coupe and they work fine and are hardly noticeable from the front of the car.
  13. gearhead1940
    gearhead1940
    friction shocks!
  14. fatabone
    fatabone
    Devin here are a couple pics.
  15. Rand Man
    Rand Man
    Yes you need shocks for stability and control. What Corn Fed described is a cl***ic case of bump steer. A good pair of shocks can mask the symtoms but the problem is still there.
  16. Devin
    Devin
    from Napa, CA
    Thanks fellas. I pretty much knew what the answer would be but had to ask anyways. I feel limited on space, so I'm looking for simple geometry and an uncomplicated appearance.
    FATABONE, your set up is spot on, I love the look and stance of your ride. what kind of shocks are those?
  17. fatabone
    fatabone
    They are the MG shocks I bought rebuilt from an early import place here in Pa.
  18. You are correct, this is one of the dumbest questions I've heard in awhile.:rolleyes:
  19. flatheadpete
    flatheadpete
    from Burton, MI
    I mad a set of friction shocks for the front of my car outta flathead connecting rods. Be creative and make 'em look cool.
  20. Bruce Lancaster
    Bruce Lancaster
    I agree shocks will prove necessary--at some point you will find a combination of bump and turn and other road cir***stances that will send the car into a tap-dancing fit. I HAVE, on the other hand, seen a few early Fords with utterly worn out original shocks that actually achieved pretty good shock type damping just from natural wear and crud...in the springs! A properly rusted spring that was last greased during the second Roosevelt administration can actually attain about the right amount damping while still springing...an organic friction shock. This is NOT a recommendation...
    I think lever shocks (hydraulic British type almost certainly better than friction) are good ways to disguise things. Early Ford hydraulics are good but impractical, as a really functional set is going to cost a lot. Another possibility might be traditional sea-leg mount tube shocks like everyone uses on early Fords, but worked into the system in front of the axle instead of behind.
