Projects Trunk lid cancer
Discussion in 'Traditional Hot Rods' started by Mike Bonnstetter, Feb 19, 2025.
  1. Fix
    6 vote(s)
    100.0%
  2. Replace
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Mike Bonnstetter
    Mike Bonnstetter
    IMG_3522.jpeg IMG_3524.jpeg I have a 1951 shoebox Ford custom just got it started working on bodywork. The trunk lid has serious cancer in it would like some thoughts on replacing the lid or fixing what I got. I’ll post pictures and fix it would you patch it? I hope this works
  2. Is it all over like that or mainly in just one or two spots?
    57Fury440 likes this.
  3. tb33anda3rd
    tb33anda3rd
    I would cut out around those holes , gradually opening up bigger till the back side of the pieces removed were not rotted on the back side. then weld a new piece back in.
    anothercarguy, vtx1800 and chlsnk like this.
  4. Mike Bonnstetter
    Mike Bonnstetter
    Just that one spot
  5. Mike Bonnstetter
    Mike Bonnstetter
    That’s what I was thinking but did know what others thought about patches.
  6. Id fix it then
    Blade58 likes this.
  7. Blade58
    Blade58
    from apopka ,Fl
    Cut out past cancer , weld in new piece , use smallest diameter wire , take your time to minimize warpage
    guthriesmith and loudbang like this.
  8. I'm shocked at how cost effective new Tig Welders are and how many home builders still insist on Mig Welding body panels. Must be the use of Body man in a Can for after welding that makes it so attractive.
    Happydaze, dogwalkin and guthriesmith like this.
  9. Squablow
    Squablow
    If that's the only spot that's bad, I'd cut it out and weld in some new steel. Especially if the inner structure is nice. Like others said, cut out a lot more than it looks like you need to.
    guthriesmith likes this.
  10. guthriesmith
    guthriesmith
    Thanks for that! I am fixing to start on a pretty big project with lots of sheetmetal welding involved and I should probably just invest in a tig. I have never really looked at pricing on them, but to your point, they are pretty dang reasonable. I am hoping to push my skill level chopping this car and doing more rust repair than I have ever had to before. Anyway, just what I needed to hear today. :D
    Sorry...back to topic at hand. :oops:
    Happydaze and Pist-n-Broke like this.
  11. Sometimes it just takes a nudge to make a Large change in what we do and how we do it. If you can Gas weld, you can Tig weld and the total change in control and finish will shock you. This is the single biggest step forward you can do in improving your Skill Level.
    Happydaze and guthriesmith like this.
