Hot Rods Trunk Lid Support mounting measurements needed for '32 Ford 3 window
Discussion in 'The Hokey Ass Message Board' started by JimMartley, Mar 29, 2021.
  1. JimMartley
    JimMartley
    HELP!! My, new to me, '32 3 window has never had a "real" trunk lid support installed. It has the old tried and true, cut down broom stick version, since it was first built in 1994. I bought a nice shiney repop Stainless Steel replacement piece for it and would like to install it correctly the FIRST time.
    The body is an older Dave Koorey fibergl*** body with no sort of markings on it as to where it needs to be drilled for the mounting points and I hope someone on this board can help me out.
  2. deathrowdave
    deathrowdave
    from NKy
    Can’t help an once with a trunk lid , I’m a rumble seat . I will look to verify if there are any mounting locations on the supports and determine measurements for you if they are present for the trunk lid .
  3. 325w
    325w
    Had a gl*** seat on a steel coupe once. The gl*** lid was marked where the mount should go.
  4. JimMartley
    JimMartley
    I had hoped the same thing...I looked mine over REAL close and I don't see anything.
  5. JimMartley
    JimMartley
    ANY help is appreciated...THANKS!!
