Technical Trying to figure correct head gaskets for 327.
Discussion in 'The Hokey Ass Message Board' started by BillSchmid, Jun 22, 2019.
  1. BillSchmid
    BillSchmid
    from Ohio
    Hi all, I am not the best with math and have my brain almost cooked trying to figure out the right thickness head gaskets to achieve close to .040 quench. My engine is as follows: 3.25 stroke. 4.030 bore. Block has been decked .015. Piston compression height is 1.671. I mulled over it a while back and I 'think' that with a .020 steel shim gasket my quench would be .037, which would be close. Sorry if this might seem a dumb question, I just don't want to order the wrong stuff.
  2. mohead1
    mohead1
    You need to know your current deck height. Surfacing .015 doesnt mean anything unless you knew what the deck was previously. So measure from the deck, to top of pistons, with each at top dead center. Record all 8. Take the lowest number of those measurements and subtract it from .040, and there is the gasket thickness needed.
    Sent from my SM-G900V using Tapatalk
  3. Deuces
    Deuces
    Yep, a depth micrometer is great for this....
  4. BillSchmid
    BillSchmid
    from Ohio
    The block was stock undecked before I sent it to the machine shop if that makes a difference. The depth micrometer doesn't seem like a pricey tool so it couldn't hurt for me to buy one.
    Deuces likes this.
  5. sdluck
    sdluck
    You can get by with a straight edge and feeler guage
    Deuces likes this.
  6. Mimilan
    Mimilan
    Factory blocks are normally 9.025" so a cut of 0.015 would yield 9.010"
    With stock rods , a 1.625 crank throw and your 1.671" comp ht pistons would leave it 0.014 below deck.
    A Fel-pro 1142026 gasket with 0.026 thickness would yield a 0.040" quench [minimum]
    It all depends on piston CC and head CC as to the desired end result.
    302GMC and Deuces like this.
  7. BillSchmid
    BillSchmid
    from Ohio
    I had not though of this. I will try that.
  8. Deuces
    Deuces
    That can work also... Still need an indicator of some sort and a mag base to find tdc....
    Truckdoctor Andy likes this.
  9. sdluck
    sdluck
    2 Find TDC put on a metal plate across using 2 head bolts but the Piston up against the metal plate marked the dampener rotated the other direction till ****s up against the plate marked Market halfway in between its TDC
    Sent from my SM-J737T using The H.A.M.B. mobile app
  10. Deuces
    Deuces
    Yes, I've seen the tool and know how it works.... I just like being more accurate....:oops::rolleyes:
  11. mohead1
    mohead1
    Do not trust that the block is the same as "others".....measure it and do it right.
    The shop cut
    015 off....why....to clean it up or to attempt a zero deck....best bet is always measure and go from there.
    Deuces likes this.
  12. Ericnova72
    Ericnova72
    from Michigan
    The former Victor-Reinz, now Mahle Original/Clevite #5746 is another .026" thick, 4.125" bore gasket. Stainless steel armor and graphite composite construction.
